1 - 1 of 1 Posts
Would like some help from someone who has used a OTC Monitor 4000 Enhanced with Pathfinder II cartridge. Van is a 1988 3.0 Voyager.
Scanner says "No data", which sorta fades in and out every second as if data is coming in though the scanner doesn't sync up with or recognize it. Any ideas what I'm doing wrong? I also tried connecting after doing the "key dance" with no luck. The scanner works fine on OBDII cars.
1 - 1 of 1 Posts
