1 - 2 of 2 Posts
Hi I need help!!!!
My van suddenly died after moving in a couple of meters and since then no spark at the coil. Changed coil-same result, changed distributor - same result, and that the ASD realy did not lay out + to the coil nad have been drowing in cables to try to fin a way through the mess. Placed the test lamp 12 v on the output Z1 from the ASD samt that goes to the coil, suddenly it led up when cranking the engine , but no start.
Any idea about what is absoulutely minimum needed to get it fired? Is it possibleto measure the pulses -somehow- to see if any pulsing really are leaving the distributor? It get 9 v supply. any other idea about what I can try?
all the best from Norway
Jack Andersen
:bcyclop:
I would sure be looking for a bad ground somewhere. Did the altenator put out 12-14 volts?
1 - 2 of 2 Posts
