should be prety straight foreward.I honestly do not know jack about 3.0's, in my case there are difereces in 3.3's from diferent year, same generation, flexplate for one, but if you stick with a long block swap you should be fine.
From what I can find on this subject, all the 3.0's are the same across the board the only difference is the distributor changed in 1996 and the injectors and wiring harness. The crank sensors started in 1996 too but they are in the tranny so that shouldn't be any issue
Hi, I have a 95 voyager 3.0l with about 245,000 km/147,000 miles on it. From the maintenance records that came with it, it hasn't had a timing belt replaced since at least the 156,000km/93,000 mile mark. (That was when one of the previous owners started keeping records, and when the...
i know this is a crazy idea but since i've seen a stock Ford Transit ice cream truck in one year's Gumball 3000 i thought about building a 87-90 ChryCo minivan when i make it in life, with a built 3000gt twin turbo 3.0 and a built 5 speed manual that's compatible with that motor (is the Getrag...
