1 - 2 of 2 Posts
i can't seem to find where to get the donut that goes in between the exaust manifold and the tailpipe. mine is badly deteriorated this is for a 94 voyager 3.0
thanks in advance
1000 Post Club Member
I got them at Advance Auto parts before, I can't imagine it being a problem obtaining them even if you have to go to the dealer. Make sure it is not just the bolts and springs that are shot. If you replace the donut, replace the springs and bolts too. The last one I put on was a bear. You may have to use a piece of 1x6 wood to beat it on. Sand the old pipe where it goes very well and you can use graphite to get it on, if you use lubes of oil they will stink after you get it on.I had to drop the pipe and loosen some other stuff to get clearance to beat the gasket on. If you have not replaced the O2 sensor right there, this is a good time to do it. You can clean the threads out with a battery terminal cleaner. The sensor comes pre lubed.
1 - 2 of 2 Posts
