1 - 1 of 1 Posts
Hello everyone,
It’s 2/12/20 - I’ve been in limp mode 3rd gear) since 12/20/20. No other symptoms!! Speedometer good, everything working.
Took it to Cottman anticipating a $3500 rebuild. He replaced a solenoid, and tested it by plugging a good valve body to the electric connector and it immediately threw the code (I’ll add code tomorrow ) suggesting the problem was electric and not mechanical.
What should I look at before surrendering and taking it to the dealer? He said wires did not look stretched, bent or otherwise distressed.
I haven’t tackled the cold-solder joint in the dash because a ground strap battery to the block solved the goofy dashboard problem.
1 - 1 of 1 Posts
