Go Back   The Chrysler Minivan Fan Club Forums > The Minivan Mopar Garage > 4th. Generation Chrysler Minivans: 2001-2007
Reply
Thread Tools Display Modes
  #1
Old 07-04-2008, 03:14 AM
HyperFox's Avatar
HyperFox HyperFox is offline
300 Post Club Member
My Mood:
Send a message via MSN to HyperFox
Intermittent Signal light Malfuction Possible Fix
Just recently had a problem with my 2007 GC and I fixed it myself. I thought it would be a good idea to pass on my findings and as It might be of some use to someone else out there someday.
Problem:
Intermittent failure or malfunction of the turn signals.
Occasionally when the turn signal lever is activated to turn on the passenger's side signal lights, the drivers side signal lights activate, or no passengers side signal lights activate at all.
Solution:
I undid the 3 screws on the underside of the steering column cover, and removed the top and bottom halves which are held in by clips. These are phillips (star head) screws, black in color.
I removed the turn signal power leads by depressing the red clip on the male end of the connector then pulled the connector out of its female portion by pressing clip downwards.
Next I unscrewed the two phillips screws on the tun signal module that bolt into the column itself, removing the module.
I noted the module was covered in a light wieght grease, which was brown in color, and was oozing out of every orafice. I cleaned this off. Next with an air compressor set to 80 psi and a narrow blowing tip, I blasted the excess grease out of the module, and removed it with paper towel.
Assembly is reverse of removal.
Hypothesis:
I believe the source of the excess grease is coming from the steering shaft itself, as it is open so the cog can strike the tab on the turn signal module to turn the signal off when the tab is struck. I believe the grease seeps onto the tab and is transfered into the module, causing a build up and malfunction.
Vehickle spec:
2007 Dodge Grand Caravan Special edition fleet quick order package with stow-n-go. 3.3L v6. 60,343km.
Hope this helps somone out as the module costs $50+
__________________
HyperFox
Proud to serve my country! Support your Canadian Troops!
2007 Dodge Grand Caravan Stow-N-Go
Visit my blog: http://hyperfox2007.blogspot.com/
Sponsored Links
  #2
Old 07-04-2008, 08:00 AM
bulldog van's Avatar
bulldog van bulldog van is offline
100 Post Club Member
they come pre-lubed
Probably your switch had loose contacts that resolved during disassembly/re-assembly, because I have a spare switch from mopar and they come pre-lubed.
bulldog van
  #3
Old 07-05-2008, 03:29 AM
HyperFox's Avatar
My Mood:
Hard to say. All I know, is it works now.
__________________
HyperFox
  #4
Old 09-07-2008, 03:04 PM
PCE Scott PCE Scott is offline
This just started happening to my van 2 days ago. Rust, failing brake lines and now this. I now understand why these vans have pathetic resale value. I bought the van because it was such a good deal and I am learning about what a good deal I got.
HyperFox, thanks for your writeup, I will give it a try.
__________________
2005 T&C Signature Series, 52,xxx miles
  #5
Old 09-07-2008, 05:14 PM
RIP's Avatar
RIP RIP is offline
Great info. thanks for passing it along. At the least , we now know how easy it is to change the switch if need be.
__________________
96 Gr Caravan LE 3.8, 206K miles
07 Fusion / 06 RAV 4 / 06 Accord / 94 Camry
  #6
Old 09-08-2008, 10:36 AM
I fixed my turn signal on Sunday watching the Bengals. Like HyperFox, I just took it apart, wiped all the grease off (quite a bit in there) and put it back together.
I think this is a pretty serious safety issue but at least it is easy to fix. I just wonder if you went to a dealer what they would do to fix it (and charge you!).
__________________
  #7
Old 09-08-2008, 11:29 AM
Jason's Avatar
Jason Jason is offline
Certified Minivan Freak
My Mood:
I thought the "reverse" turn signal thing happened to me once on the road. I never could get it to do it again, though. And I must have missed this post when it was first posted. Thanks for the write-up!
__________________
2007 Chrysler Town & Country Touring Signature Series (Cognac Crystal Pearl)
2007 Toyota Corolla LE (Desert Sand Mica), 1997 Dodge Dakota Sport (Emerald Green Pearl)
Former:
2003 Dodge Grand Caravan Sport, 2001 Cadillac STS, 1997 Cadillac SLS, 1997 Saturn SC2, 1995 Nissan Hardbody 4x4, 1987 Buick Regal Limited, 1984 Oldsmobile Cutlass Calais
  #8
Old 11-23-2008, 01:43 PM
eljefe91 eljefe91 is offline
Newbie
Thanks Hyperfox. I've had this problem for over a year and it's been frustrating. I have to get the car inspected every year (Massachusetts) so I ended up timing the inspection last Dec for a time when the signal was working. I already paid a mechanic $90 to change the relay to no avail. I will follow your procedures when my wife brings the van home today.
  #9
Old 11-26-2008, 09:39 AM
AzTraveller's Avatar
AzTraveller AzTraveller is offline
My Mood:
Quote:
They do come prelubed, to allow them to rub, but not wear out too fast. The grease oozes out when there is excessive heat, caused by the contacts becoming warn (loose/intermittent) and getting hot when you switch them. Once you have access to it, you may wish to adjust the tension on the contacts, or simply replace it, since you're there, and "no worries".
__________________
1990 Plymouth Grand Voyager LE 3.3L LWB-- 198k miles and counting ......
318,650.1 kilometers, for you metric buffs ......
  #10
Old 12-14-2008, 12:28 AM
Newbie
I took mine apart today but discovered that the grease in there was to lube the parts of the switch so I left it alone. I may go to a junkyard to get a replacement. How common is this problem?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
89 3.0L Intermittent Stalling Roadtrip 1st Generation Chrysler Minivan: 1984-1990 8 08-01-2008 02:24 AM
Intermittent Oil Light Vinci 2nd Generation Chrysler Minivans: 1991-1995 14 03-05-2008 09:58 AM
intermittent brake and check engine light tempfixit 2nd Generation Chrysler Minivans: 1991-1995 4 03-02-2008 04:52 AM
Intermittent air bag light Uncle Scrooge 4th. Generation Chrysler Minivans: 2001-2007 2 01-24-2008 07:55 AM
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2001 - 2009 GJM Ventures Inc. All Rights Reserved
