Go Back   The Chrysler Minivan Fan Club Forums > The Minivan Mopar Garage > 3rd Generation Chrysler Minivans: 1996-2000
Reply
Thread Tools Display Modes
  #1
Old 02-01-2006, 09:14 PM
cchovaz cchovaz is offline
Newbie
Check engine soon code P1494
97 Plymouth Grand Voyager 3.3 engine, any part specific to look at as the code comes back with Leak Detection, pump pressure or Mechanical Fault.
Sponsored Links
  #2
Old 02-01-2006, 09:30 PM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Global Moderator
My Mood:
Send a message via MSN to AMD Rules
Fisrt, make sure your gas cap is tight. You can get a code with a loose gas cap. Tighten it, disconnect/reconnect batery, and then wait a few trips to see if the code clears.
If its not that, you may have a leak in your system.
__________________
2007 Grand Caravan SXT, 3.8L 4-spd, Inferno Red, 45,500 kms 2001 Dodge Dakota Club Sport , 3.9L 4-spd , Flame Red , 165,000kms
  #3
Old 02-01-2006, 09:52 PM
Newbie
Thanks, I have noticed that there is only pressure at the gas cap sometimes when removed to fill. Should it be there all the time when opening?
  #4
Old 02-01-2006, 11:14 PM
hardrock2 hardrock2 is offline
Newbie
I had that same code one time on my other 98 gv when my wife left the gas cap off after filling the tank like AMD said take the cable off and clear the codes thats all it took for mine .
  #5
Old 02-02-2006, 09:49 AM
DSMLVR's Avatar
DSMLVR DSMLVR is offline
Senior Global Moderator
My Mood:
For the newer vans, you have to drive it a few weeks before the code will clear (AFTER you retighten the cap). It does tests on the system when you start and when you drive. It takes a certain amount of 'OK' tests before the code will clear. The other option is to take it in to the dealer and have them clear it, for $$$$.
__________________
Avatar: EconoVoyager Concept
  #6
Old 02-02-2006, 06:22 PM
Newbie
Quote:
I tried tightening the Gas Cap and reset the codes, all clear so far and have driven the vehicle 3x today, no re-occurance so far
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
check engine on code p1698 carpa1330 3rd Generation Chrysler Minivans: 1996-2000 7 04-18-2009 06:56 PM
Check Engine Code: P0171 jcrew_2 4th. Generation Chrysler Minivans: 2001-2007 2 05-08-2008 03:35 PM
***HELP, check engine code 43 and 12*** kcomplita 3rd Generation Chrysler Minivans: 1996-2000 3 12-04-2007 05:40 PM
Check Engine Light and Code? JEC 4th. Generation Chrysler Minivans: 2001-2007 7 05-31-2006 12:40 PM
check engine light code rwcrazy 3rd Generation Chrysler Minivans: 1996-2000 3 09-02-2004 02:28 PM
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2001 - 2009 GJM Ventures Inc. All Rights Reserved
