2005 Town and Country door lock problem
Results 1 to 7 of 7
Thread: 2005 Town and Country door lock problem
    Sep 2008
    1
    Question 2005 Town and Country door lock problem
    I have a 2005 Town and Country minivan. Lately the automatic door locks will not work. The button on the door nor the remote key will not lock them but I can lock them manually or use the key in the lock to lock the drivers side door and the lift gate door. Any ideas?
    Apr 2007
    Southwest
    3,700
    Country: Users Country Flag
    79
    Not up on the particulars on your system but it appears in true Chrysler fashion, they have integrated nearly all functions of the door lock system into the Body Control Module better known as the BCM. No relays in generation 4 vans. What that boils down to is instead of spending $10 on a relay you now spend $300 on a BCM.
    Besides the BCM you could have a wiring problem or...find the IOD fuse in the fuse box next to the battery. It may be labeled "Memory". Remove it for a few minutes then reinstall it. This will reset the BCM and hopefully your door locks.
    I'm assuming the locks won't lock from either of the front door switches.
    96 Gr Caravan LE 3.8, 206K miles
    07 Fusion / 06 RAV 4 / 06 Accord / 94 Camry
    Sep 2008
    1
    same problem
    Quote Originally Posted by witchywoman View Post
    I have the exact same problem. I can remove the iod fuse and plug back in and the locks will work one or two times then quit again. Some have said the problem is in the body control module but I belive it's a bad connection somewhere. Anybody have a solution?
  5. #4
    Oct 2007
    Auburn, GA
    388
    5
    This has been a constant problem on my van too. The BCM has been replaced 3 times I think. The have reflashed it or reprogrammed it. Replaced the front lock switches. It has been almost a year and they still don't work right. Pulling the IOD fuse usually resets mine for about a week.
    I have it sceduled for another dealer visit on OCt 7th.
    Replacing the battery helped for along time. Check your battery and connections.
    Allen
    2005 T&C Touring. 3.8L Midnight Blue. 117K
  6. #5
    Apr 2008
    New England, USA
    1,659
    20
    Quote Originally Posted by katoranger View Post
    Wow. 3 BCM's! That sounds expensive. The BCM's are supposed to be able to do some level of self diagnostics... did any codes show up saying that the BCM was bad?
    Advice: if they want to replace it again, try a different shop.
    My other thought is that if the BCM is dying this frequently, there is probably something else wrong, other than y our door locks. The door locks may simply be a symptom.
    2009 Dodge Grand Caravan SXT (3.8L), Light Sandstone Metallic, 105K miles
    2005 Volvo XC70, 152K miles
    Previous van: 2002 Chrysler T&C, eX (3.8L)
  7. #6
    Oct 2007
    Auburn, GA
    388
    5
    I haven't paid for a one yet. All been on the dealer/chrysler. The problem was found shortly after I got the van home from purchasing it.
    They thought it was the door lock switches and replaced them. Still not working right.
    We will see.
    Allen
  8. #7
    Jan 2006
    3
    Hi, it's a temporary fix but worked on my 2005 touring. Disconnect the -'ve battery lead - leave off for ten minutes and then re-connect. Gary
  1. door lock problem
    By Bill McKeown in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-16-2012, 02:58 PM
  2. AC oil 2005 Town and Country
    By L22 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-19-2009, 11:45 PM
  3. remote door lock problem
    By VANGO in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-07-2009, 07:04 AM
  4. 2005 Town & Country Air Bag Light
    By David Kingston in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-04-2008, 05:25 PM
  5. door lock problem
    By mrteacha in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-16-2005, 09:37 PM
  • You may not post replies
