WHY??? Speedometer Needle Reset
Results 1 to 10 of 13
Thread: WHY??? Speedometer Needle Reset
    Mar 2007
    Holland, MI
    1,613
    7
    I walk outside last evening to hear my neighbor cussing while under the hood of his 2001 GC with 105k on the ticker. So, I walk over and see if I can be of help.
    His speedo needle is on the wrong side of the needle. I laughed and showed him how to fix it. Thank you chryslerminivan.net.
    This leads me to my why question. I have personally owned 45 automobiles and have fixed at least that many others for others. I have NEVER heard of such a stupid failure with such and easy fix. Fine it is easy to fix but........
    Why did Chrysler have to make the IP that way? Why on some vans does the IP prevent the vehicle from even starting? Seems to me like a stupid thing to be dependent on.
    2010 Honda Oddy LX - 9k miles - Land Barge
    2008 Honda Fit Sport - 31k miles - What a riot!
    1996 Toyota Land Cruiser - 292k miles - Tank
    Gone - 2001 DGC Sport 3.3L 169K
    Apr 2007
    San Diego
    5,212
    Unfortunately, the electronics that "the powers that be" have piled on these wonder wagons don't always work as advertised. They are suseptable to power surges and below spec voltages usually caused by poor connections or weak batteries. The self test feature is there to help us overcome these glitches. I'm not telling you anything you don't already know. Just throwing my two cents on the table.
    As far as the IP causing no starts etc, all I can come up with is it appears it was all an attempt to improve mileage and cutting pollution by eliminating quite a bit of wiring, inturn, weight. I'm talking about the CCD multyplex data bus. Depending on the fail mode, if the bus fails you get no starts. Unfortunately that means obscure units can cause seamingly unrelated problems.
    Jun 2007
    Stuck in NJ Traffic
    1,234
    Quote Originally Posted by averkam View Post
    Did you learn any new phrases?
    If you just recalibrated the pod, you fixed the symptom, not the actual problem. His battery is getting weak (or he has a bad connection).
    <cue the ominous church chorus> The needle flipping is a SIGN... it's a weak battery that, if left unheeded, will result in more cussing when the car doesn't start.
    Years ago (the 80s), when the battery got weak, the period radios would lose all their preset memory, and you knew it was time to find a good sale on a battery. In these vans it's the speedo needle jumping at engine start that gives the same indication. (It probably jumped for months before it flipped all the way around to the dark-side of the instrument!)
    Hey, anybody remember the REALLY old days when slow cranking meant the battery was getting old?
    I'm with Shipo or whoever, that recommended replacing the battery every five years regardless. There are just too much electronics that can get flaky when the voltages drop....
    Atwell "Buff" Haines
    Northern NJ
    2002 Grand Caravan ES "Extra Special"...
    Blue
    3.8L, Touring Suspension, 17" Alloys, and Autostick
    Mar 2007
    Holland, MI
    1,613
    7
    Quote Originally Posted by Carbuff2 View Post
    Good advice. I did tell him to replace his battery but did not know that the needle flipping was one of the indicators. I just looked at the battery and saw lots of crap on the terminal (another old indicator that the battery was headed out).
    Jan 2005
    Fayetteville, NC
    9,436
    I can attest to that. When I was having battery cable problems on our '07, the needles would rotate clockwise all the way to the right, then "reset" back to the left when the engine started. Seemed to be related to the bad battery connection.
    Jul 2008
    New England
    9
    ...Hey, anybody remember the REALLY old days when slow cranking meant the battery was getting old?
    I say we revert to 6 volt systems. Talk about slow crankin'!! But they'd always start...
    Jun 2007
    Stuck in NJ Traffic
    1,234
    Quote Originally Posted by Pepperell View Post
    I have a friend with a 53 DeSoto that would argue with you on that!
    Northern NJ
    Blue
    Aug 2007
    53
    I need some help. Speedo is jumping erratically when driving and transmission shifting a little hard. The engine light came on P1684 indicating battery disconnnect. It i9s raining and wet so I expect some electrical issue. Transmission fluid is not burnt.
    Apr 2007
    San Diego
    5,212
    Quote Originally Posted by mjt View Post
    Sounds like the output speed sensor is headed south. It's the sensor on the far right front to the right of the shift lever on the 4 speed 41TE tranny. Easy screw out screw in change. Check the connection and wire harness first if you decide to change it. This sensor is the sending unit for the speedometer and the Transmission Control Module uses it to determine shift points.
    Did your engine light come on and go off? A P1684 code normally won't turn on the light. It means the Powertrain Control Module momentarily lost power. The usual reason is the battery was disconnected.
    Dec 2004
    Virginia
    4,029
    I would suggest checking the battery terminal connections to make sure they are tight. Lots of strange things can happen if your battery is not connected tightly.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
  1. Speedometer needle stuck on wrong side of pin
    By BlackOnBlackCobra96 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-14-2015, 06:32 PM
  2. Speddo needle sits a 20 mph
    By Dexterdog in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-02-2010, 11:40 PM
  3. Speedometer needle is going crazy
    By chicago in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-05-2008, 11:57 PM
  4. Can Sentry Key Be Reset
    By Flavife in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-11-2007, 10:27 PM
  5. 96 Voyager, engine hiccup and speedometer needle went wild
    By happycamper in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-14-2005, 02:44 AM
