dash light replacement ?
Results 1 to 5 of 5
Thread: dash light replacement ?
    Oct 2007
    somewhere around Carlisle, PA
    63
    how hard is it to replace a burnt out light bulb behind the speedometer?
    its the bulb that lights up the first 25 mph.
    is it a pain? should i replace all of them while im in there?
    '03 GC Sport
    3.8L Midnight Blue 93k miles
    '93 Concorde LXI
    3.5L 367,000 miles and counting.
    Dec 2004
    Virginia
    4,029
    It's not very difficult. It is easy to remove and replace the cluster. The hardest part is removing the bulb from the plastic housing. You can buy the bulbs already in the housings. They cost a little more and in my experience they are harder to find. I don't remember the bulb number, but do a search here and I'm sure you'll find it.
    There are a total of 8 bulbs back there--one each for the fuel and temperature gauges, and three each for the speedometer and tachometer (if you don't have a tach, I don't know how many bulbs, but there are not more than 8, and probably 5 or 6). Yes, you should replace all 8 bulbs when you do this. Since all of the bulbs are 5 or 6 years old, it is likely you will break a filament in at least one of the other bulbs, just from the impact of removing and reinstalling the gauge cluster. If you don't replace all of them, you'll have to take it out again and replace them anyway (That's what I had to do).
    Definitely one of those jobs where the satisfaction of doing the job is greater than the work involved.
    Michael
    Centreville, VA
    Currently driving: 2015 Jeep Cherokee Trailhawk
    Former owner of:
    2005 Dodge Grand Caravan SXT, 129K mi.; 2008 Nissan Quest, (2008-2010, 25K mi); 2003 Grand Caravan Sport, 3.8L, (2004-2008, 106K mi); 1995 Plymouth Grand Voyager SE "Rallye", 3.3L (1995-2004, 169K mi); 1988 Dodge Caravan SE, 2.5L I4 (1988-1995, 99K mi);
    Oct 2007
    63
    MMAHAMM - an interesting tidbit for you. we both own the same year and model van, and we both live in Centerville. although, my centerville is in pennsylvania.
    thanks for the info on the lites!
    '03 GC Sport
    '93 Concorde LXI
    Jul 2007
    St. Clair Shores, MI (near Detroit)
    57
    1
    Try using the search function for detailed instructions about removing the dash panels etc. Search "INSTRUMENT CLUSTER LIGHTS". There are quite a few tips already in those threads that will help you. They were the first threads I used on this forum and they really helped. Since then, i have fixed several things I might not have tried without this forum. Good Luck.
    Dec 2004
    Virginia
    4,029
    Quote Originally Posted by wabash View Post
    Where in Pennsylvania is Centreville? Google Maps cannot find it for me.
    Michael
    Centreville, VA
    Former owner of:
  1. Need dash light feed on 2007 T&C
    By holabr in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-05-2010, 12:53 PM
  2. Light In Dash Went Out
    By norulesjustgo in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-09-2010, 12:16 AM
  3. Partial dash light issue
    By PT_Sean in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-08-2008, 09:39 PM
  4. 02 T&C no dash light
    By BW"s in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-31-2008, 12:04 PM
