P0441 code is not the NVLD
Results 1 to 4 of 4
Thread: P0441 code is not the NVLD
    Sep 2006
    515
    2
    I posted about swapping out the NLVD (natural vac leak detection assembly) because my '01 Voyager 3.3 Flex Fuel was throwing a P0441 code. Everything fit together well enough on the swap. However, I'm throwing out this code again. Anyone have other suggestions as what could be wrong?
    2014 Chrysler Town & Country 30th Anniversary Edition
    2007 Acura MDX
    1996 Mustang Cobra
    1995 Lincoln Mark VIII
    Mar 2007
    2,956
    Emissions leak. You just ruled out the NVLD was broken, leaking, or disconnected - throwing the code and MIL. It is (and was) detecting a leak in the EVAP system.
    P0441 (M) Evap Purge Flow Monitor Insufficient or excessive vapor flow detected during evaporative emission system operation.
    P0442 (M) Evap Leak Monitor 0.040 Leak Detected
    A 0.040 leak has been detected in the evaporative system.
    P0443 (M) Evap Purge Solenoid Circuit An open or shorted condition detected in the EVAP purge solenoid control circuit.
    P0452 NVLD Pressure Switch Stuck Closed NVLD pressure switch stuck closed.
    P0453 NVLD Pressure Switch Stuck Open NVLD pressure switch stuck open.
    P0455 (M) Evap Leak Monitor Large LeakDetected
    A large leak has been detected in the evaporative system.
    P0456 (M) Evap Leak Monitor 0.020 Leak Detected
    A 0.020 leak has been detected in the evaporative system.
    (M)=MIL lit
    -Jim
    Sep 2006
    515
    2
    What are the other components in the EVAP system?
    2007 Acura MDX
    1996 Mustang Cobra
    Apr 2007
    San Diego
    5,212
  1. P0441 Code Related to Slow Fuel Fill?
    By rmaxey in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-12-2010, 04:58 PM
  2. Anyone deal with code P0441?
    By BlackOnBlackCobra96 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-13-2008, 08:52 PM
  3. Hi, I'm new here. Got P0441
    By paco30024 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-14-2008, 09:16 PM
  4. NVLD Location
    By Consultant in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-20-2007, 05:50 PM
  5. code 72
    By voyager_gdl in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-23-2007, 07:20 AM
