timing chain
Results 1 to 10 of 15
Thread: timing chain
    May 2008
    5
    timing chain
    i noticed on the 98 caravan's 3.3 engine there is no mention in the manuel about timing chain replacement,where as on the smaller engines they mention replacing the timing belt at certain mileage.On the 3.3 engines,this is not required or what
    May 2006
    New Hampshire
    8,368
    Quote Originally Posted by crankcase View Post
    Nope, no requirement for a change... ever. Same with the 3.8. The only engine now available here in North America in a Dodge or Chrysler minivan that sports a timing belt is the new 4.0 liter unit.
    Apr 2007
    San Diego
    5,240
    Quote Originally Posted by shipo View Post
    Chrysler just can't let go can they?
    Apr 2008
    15
    Any timing chain can require replacement.........Depends on many factors. I believe I read 1 inch of play? For the 3.8 engine.
    I just replaced one on my Dads 2000 GC 3.8 His 1991 GC 3.3 was OK and it had more miles on it.
    I have read many manuals over the years and seen lots of specs. There are always specs for whether the timing chain is OK.
    If this is not the case then explain why the 2000 GC 3.8 with 138K miles was worn past spec and the 1991 GC 3.3 at 200K was not?
    Jul 2003
    High Ridge, Missouri
    4,760
    Most people will never have to change a timing chain on a 3.3/3.8 Liter engine.
    That being said, there is no REQUIRED or SCHEDULED MAINTENANCE or MAINTENANCE INTERVAL listed for the timing chains. That does not mean that they do not stretch or break. It is just that they usually do not require maintenance over a normal lifetime. Towing, hard driving, jack rabbit starts, (eg. HARD USE), can require maintenance but , unlike timing belts, they do not require a SCHEDULED MAINTENANCE
    Avatar: EconoVoyager Concept
    Aug 2007
    Winnipeg, MB, Canada
    527
    5
    Does anybody know if chrysler still uses plastic gears? I did a timing chain job on my old '73 cornet years back, and I was surprised to find that the teeth on the gears were plastic. It seemed like a stupid concept to me at the time. (especially considering there was only 7 good teeth between both gears remaining)
    If at first you don't succeed, get a bigger hammer!!
    Current ride:
    2005 Dodge Grand Caravan SXT (3.8L, purchased at 108,000kms. Now at 166,000km and counting)
    Past rides:
    1997 Dodge Caravan Rallye (3.3L 242,000kms)
    2002 Chevrolet Cavalier (Base Model)
    1988 Ford Ranger (2.9L 2wd)
    1973 Dodge Cornet Wagon (318 cid)
    1965 Rambler Classic 550 4 dr (232 cid)
    1966 Rambler Classic 55 Wagon (232 cid)
    Apr 2008
    15
    DSMLVR I agree with what you say. The reason my dad's 2000 needed them replaced is because the previous owner went too long on oil changes.
    The PCV system was clogged up as well. I am rescueing it from the last owner's neglect.
    I believe that the plastic coated metal gears went out in the late 70s. I believe that all vehicles use metal now. The 1991 3.3 and 2000 3.8 were all metal.
    Aug 2007
    527
    5
    Quote Originally Posted by syntheman View Post
    DSMLVR .
    Thank goodness!!! What were they thinking with that one?!?!
    Current ride:
    Past rides:
    May 2006
    New Hampshire
    8,368
    Quote Originally Posted by kenmore63 View Post
    Trying to reduce chain noise, go figure.
    May 2006
    45
    Even worse were the plastic distributor gears on the slant-six which broke and usually stopped the vehicle wherever you were at the moment.
  1. timing chain in 94 3.8 L
    By donnf in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 11-18-2010, 02:07 PM
  2. Timing Chain
    By dirtbroker in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-01-2008, 08:39 PM
  3. Timing Chain 92 3.3 ? ?
    By repoxp777 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-31-2008, 02:29 AM
  4. '91 GC AWD 3.3 V6 Timing Chain
    By akoos in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 06-07-2007, 11:57 AM
