check engine on code p1698
Results 1 to 8 of 8
Thread: check engine on code p1698
    May 2008
    Garland TX
    10
    Unhappy check engine on code p1698
    Hello
    I have a 1997 chrysler mini van, the check engine ligth came on
    so i went to autozone and the code they give me is p1698, i read
    on this site about the cluster having problems n all the symptoms n those
    problems i had but it wasn't that bad, so i fix the solder on the cluster, is the check engine ligth going to go off on its own.
    Thank u for your help.
    Nov 2007
    Windsor, Wisconsin
    191
    Disconnect the battery cable for a few minutes and see if comes back on, quickest way to find if you have other problem with the bus connection to TCM.
    May 2008
    Garland TX
    10
    thanks im going to drive it n see if the ligth come back on .
    Feb 2007
    Lancashire, UK
    913
    2
    P1698 is not related to the instrument cluster problem you had.
    • P1698 PCM Failure EEPROM Write Denied
    • P1698 -No CCD messages from the Transmission or Body Control Module (TCM or BCM)
    Try using a contact cleaner on the connections to PCM, TCM & BCM and ensure they are seated properly.
    '97 Chrysler Grand Voyager 3.3 LE (UK Model) , 167,000 miles. Dual Fuel Petrol/LPG. Tow Pack.
    Now sold. New owner is using as a project ! Replaced by a 2000 Nissan Primera 2.0L Sport+
    Dec 2006
    1,113
    31
    Quote Originally Posted by Renegade1127 View Post
    I have no idea which of those two code versions this could be, but if it is a p1698 "no ccd messages from tcm or bcm" code, it indeed can be due to the instrument cluster problem. If the instrument cluster connector fails, it can take down the CCD bus with it due to the way the signaling works, which will cause the other modules to complain about not being able to talk to each other.
    - G
    1998 Grand Voyager @336,000mi, 3.3L FFV V6
    Feb 2007
    Lancashire, UK
    913
    2
    Quote Originally Posted by greenlight View Post
    - G
    I stand corrected Sir.
    That's what I get for trying to be logical - forgot there ain't nothing logical about Minivan electronics
    May 2008
    Garland TX
    10
    thank u guy's! i put about 50 miles since i work on it n the ligth still off
    so i hope i got it.
    Apr 2009
    2
    Where do I find the harness to the TCM?
  1. check engine code?
    By olstyl1972 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-20-2010, 04:21 PM
  2. Check engine light code
    By obtude in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-26-2009, 07:01 AM
  3. ***HELP, check engine code 43 and 12***
    By kcomplita in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-04-2007, 04:40 PM
  4. Check Engine Light and Code?
    By JEC in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-31-2006, 11:40 AM
  5. check engine light code
    By rwcrazy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-02-2004, 01:28 PM
