999 Code?
Results 1 to 6 of 6
Thread: 999 Code?
    Mar 2005
    Lenoir,N.C.
    75
    999 Code?
    I'm asking for a friend, that ownes a plymouth voyager,1999 v6, 3.3.
    He done the key dance and got a 999 can anyone tell me what this is?
    Thanks in advance
    hope
    1998 Dodge Caravan 3.0 76,000 miles (new engine)
    1996 Toyota Truck
    Dec 2006
    1,106
    31
    If you did the key trick where you hold down the trip and reset buttons while turning the ignition on, a 999 code means "end of codes" --> the instrument cluster did not store any trouble codes.
    BTW, does the key on-off-on-off-on trick work on your van? I've never been able to get that to work on mine.
    - G
    1998 Grand Voyager @333,000mi, 3.3L FFV V6
    Mar 2005
    Lenoir,N.C.
    75
    Nope, he done what some one else had posted on this site about the trip/reset, turn key to on wait 5 seconds, then release.
    His check engine light is on and want go off but that is the only code he can get.
    hope
    1996 Toyota Truck
    Apr 2007
    San Diego
    5,212
    He performed an instrument cluster calibration. "P" or scanner codes are what turn on the Service Engine light. To get the P code he can either do the key dance and read them off the odometer or better yet, go to your nearest AutoZone where they will connect a scanner and read the P codes. It's free.
    All P/scanner codes have 4 digits preceded by the letter P.
    Is he seeing any symptoms along with the SE light? If it's running great a leaking gas cap seal can produce the light. Try tightening the gas cap.
    Mar 2008
    17
    Hi we have 97 voyager with service engine light on runs great small rust hole in muffler but wife said it came on after it was run low on gas but not out ? the gas cap is tight oil is good what else is there to check ? done the speedo thing that I read on hear very heplful and the code there was 999 ? thanks in advance, only 120.000 miles on it.
    Mar 2005
    Lenoir,N.C.
    75
    It turned out his was the EGR valve and he had it put on machine and thats what they told him it was. Hope it helps.
    hope
    1996 Toyota Truck
  1. CEL -- code 39 (?)
    By marco999 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-22-2009, 07:23 PM
  2. Hello and DTC code
    By psal2 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-24-2007, 03:20 PM
  3. code
    By brownjug in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-28-2006, 07:07 PM
  4. OBD Code
    By rgsellers29 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-19-2006, 11:16 PM
