2007 Town & Country Lights Flickering
Results 1 to 10 of 11
Thread: 2007 Town & Country Lights Flickering
    Apr 2008
    3
    Hi new to the post. I have a 2007 Chrysler Town & Country Limited 7000 miles and have a problem with lights flickering Chrysler bought back my 06 for this problem at 3000 miles. Dash, headlights, dome, & tail lights all flicker. I took in 2nd time now and the filed rep from chrysler looked at it and demed it undriveable but they let me pick it up. They told me both times to stop useing my heated seats. I have been pulled over once for it because the cop thought that i was flashing my lights at him, its that bad. I was wondering if anyone esle has had this problem and what they did about
    Paul
    Jan 2005
    Fayetteville, NC
    9,436
    If a representative from Chrysler deemed it undriveable, bring it back to the dealership, park it, and insist on a loaner car until they fix it. If their recommendation (Chrysler's) is that you can't drive the car, they've backed themselves into fixing it. I would get insistent with them.
    And welcome to the forum!
    Apr 2008
    Minnesota
    6
    Hi, I'm also new here, and had a similar problem although from your description probably not as bad. All lights flickered, it was most noticeable in the headlights, overhead lights, and gear indicator. Very annoying. I have an 05 Dodge SE+.
    Turned out the battery ground cable was corroded. After cleaning it up no problems. I have a hard time believing a dealer couldn't find or diagnose a bad ground, but I've heard of worse.
  5. The Following User Says Thank You to plmn For This Useful Post:
    Isael(11-19-2014)
  6. Remove Advertisements
  7. #4
    Apr 2008
    3
    They replaced the battery the last time I had it in and it still does the samething. The flickering is as bad as a strobe light. This is pretty horrible for a almost $40,000 van and they tell you to stop using the heated seats. The last time I checked that was one of the reason that I bought the van.
  8. #5
    Jun 2005
    KS
    1,291
    2
    It's been my experience that some minor flickering is indeed normal. However, if it's bad enough for a police action then a decent tech should be able to find the voltage drop.
    My 2 cents,
  9. #6
    Feb 2008
    Bedford,VA
    29
    The ground cable where it attaches to the frame must have a bad connection.
  10. #7
    Oct 2007
    Petawawa, Ontario
    312
    I get the flicker, but its nowhere as bad as this. Mine is barely noticeable and happens when the A/C compressor kicks in. Which in my eye seems normal.
    Ill echo the others here.. Start yippin at them.
    HyperFox
    Proud to serve my country! Support your Canadian Troops!
    2007 Dodge Grand Caravan Stow-N-Go
    Visit my blog: http://hyperfox2007.blogspot.com/
  11. #8
    Apr 2008
    3
    They checked all grounds
  12. #9
    Dec 2008
    1,985
    Sounds like a control module connection.
  13. #10
    Apr 2007
    San Diego
    5,208
    I've read of corrosion at the Front Control Module (FCM) connection to the Inteligent Power Module (IPM) (fuse box next to battery) causing lights problems. The FCM is on the front of the IPM. Might check there.
  1. No Heat 2007 Town & Country
    By fsdmark in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-11-2016, 08:54 PM
  2. 2007 town and country dies after startup???
    By triathloner in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-20-2010, 10:43 PM
  3. 2007 Town and country 3.8 gas mileage
    Last Post: 03-06-2009, 02:40 AM
  4. 2007 Town and Country Review
    By DSMLVR in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-06-2007, 04:12 PM
  5. 2007 Dodge Caravan/Town & Country Info
    By vanjeff in forum The Fireplace
    Last Post: 09-26-2006, 01:06 PM
