Location of OBD connector on 95 Caravan 3.3L
Results 1 to 3 of 3
Thread: Location of OBD connector on 95 Caravan 3.3L
    Apr 2008
    1
    Where is the OBD connector located on a 1995 Caravan 3.3L? Want to connect a scan tool (INNOVA 3140) using Chrysler OBD1 cable/connector, but the small black connector under the steering column/dash appears to be too small. Where is the proper connector located to connect the scan tool in order to read a "check engine" code? Does anyone have a picture or can clearly describe where the connector is located? Thanks!
    Ken
    Nov 2007
    Windsor, Wisconsin
    191
    Check this site should help you, it in the engine compartment:
    http://www.autozone.com/az/cds/en_us...rInfoPages.htm
    Hope this helps
    Oct 2007
    Vermont
    1,332
    Under the hood, large black plastic squairish looking plug with a protective cap on it. If I remember correctly, it is either on the passenger side near the fire wall, or the driver's side near the strut tower.
  1. Blower motor resistor location in '96 Caravan
    By donevan in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-20-2010, 06:20 PM
  2. Location of Front O2 Sensor Connector
    By marvinstockman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-12-2009, 11:47 PM
  3. 2003 Caravan power window circuit breaker location
    By Fatair in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-08-2008, 05:55 PM
  4. Flasher Unit Location on 2001 Grand Caravan Sport
    By Paul Jones in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-19-2008, 01:54 AM
  5. 2002 Dodge Grand Caravan Cabin air Filter location...
    By theboneskes in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-11-2007, 06:10 PM
