2003 Town & Country Speedometer and Tachometer
Results 1 to 5 of 5
Thread: 2003 Town & Country Speedometer and Tachometer
    Mar 2008
    2
    Please someone, recently our speedometer and tachometer has stoped working. Both needles are on the opposite side of the zero pin. The battery has not been touched (changed out, all normal) and all other instruments and gauges appear to be working fine. I have tried the reset procedure I have read on other forums but this didn't work. I tried disconnecting and reconnecting the battery and that didn't work either. I looked at the fuses under the hood and saw none to be blown. What is causing this and how can I fix it.
    Sep 2007
    West Michigan
    650
    5
    You tried holding down the odometer reset button until sof appears?
    2011 Chrysler Town & Country Touring | 2008 Toyota Camry Hybrid | 2002 Jaguar X-Type 2.5 AWD | 2003 Yamaha V-Star 650 Classic
    Mar 2008
    2
    Quote Originally Posted by DGC View Post
    Yes! That was the reset I mentioned. sof appeared, then the gauges all came to life, like a reset should, but for the speedomter and tachometer.
    Jun 2004
    rochester,ny
    736
    7
    Might be dealer time . I would try the reset procedure at least 2 or 3 times to rule that out .
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    45000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Feb 2008
    9
    This happened to me a couple weeks ago. There was some mysterious issue with my turn signals. When you put the signals on, the dash power shut down.
    I had to remove the instrument cluster, take the front facia off and physically turn the needles counter clockwise to bring the to the correct side of the pin. Fortunately, the turn signal problem fixed itself.
    Good luck
  1. help with 2003 town and country
    By kimsmithie in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-03-2010, 01:00 PM
  2. Speedometer and Tachometer gauges off on 96' Caravan
    By 22bad4u2 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-23-2009, 10:47 PM
  3. Tachometer and Speedometer Stopped Working
    By SaltAquatics in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-04-2008, 08:55 PM
  4. Any ideas on how to tow a 2003 Town & Country?
    By jdetzel in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-24-2008, 11:41 PM
