2001 Grand Caravan blower resistor and cabin filter
Results 1 to 10 of 11
Thread: 2001 Grand Caravan blower resistor and cabin filter
    Feb 2008
    1
    Cool 2001 Grand Caravan blower resistor and cabin filter
    Does anyone have a schematic or picture of where my cabin filter and my heater blower resistor are located?
    My blower resistor has went out twice in 18
    months and the last time the service shop replaced it. This time I want to do it myself. I have read this forum, and the Chilton manual(bad pictures) and it states that the heater blower in 2001 and later models is in the center of the dash behind the cosmetic panels on the dash, but I have read in this forum with other owners of vans later than 2001 that the blower and cabin filter is located behind the glove box...which is it?
    You can email me the pictures or schematics to biking4lifemike@yahoo.com
    Thanks, Mike
    Sep 2007
    14
    filter is below the glove box. In the passenger foot well area. The blower resistor is located behind the glove box. Open the glove box and squeeze the roller in to lower the glove box
    Jan 2008
    Southeast Arkansas
    432
    After you get the glove box open you will see a rectangle "box" mounted with 2 screws to the duct behind the glovebox with 3 or 4 wires running into it..That is the resistor...The filter goes into the same duct from the bottom..There is a large plastic "keeper" you will have to remove and after that the filter will slide out the bottom...
    Hope that helps..
    GASMAN :
    2008 Town and Country Touring
    Liquid Silver
    1995 Jeep Cherokee Sport with 2" lift on 31's
    MUD TOY
    Feb 2008
    3
    I have been searching for answers to my heater fan problems and I think you guys have supplied the answer. I am checking on the blower resistor today and will let you know about fix. Thanks
    Feb 2008
    18
    I believe there are different versions of the blower resistor depending on if you have climate control. Of course I have climate control and the resistor was $75 at the dealer - a lot of electronics on it.
    In terms of the cabin filter, I found out something interesting when I changed my resistor. My wife's van has the 3 zone climate control. There is a pipe that runs along side the cabin filter. You only see this if you remove the resistor. If you have the multi zone heating, and your cabin filter does not want to seem to go in, take out the resistor and you will see the hold up (the extra heating pipes).
    Feb 2008
    3
    Just a thank you to all who had solutions to the T&C blower fan problems. The blower resistor was the problem and 10 minutes after I picked up my replacement part it was fixed. It does give you a good feeling to fix one yourself. I really appreciate the help. Rick
    Jul 2003
    High Ridge, Missouri
    4,760
    Welcome to the Forum and glad you are up and running properly again.
    Avatar: EconoVoyager Concept
    May 2008
    Minnesota
    7
    This is my first visit, and thank you for all of the good information. My 2001Voyager also has a bad resistor pack. Thanks to your posts, I found resistor pack quickly behind the glove box. You guys did all the hard work for me. I greatly appreciate it.
    Now, the long version.....
    OK, I'll admit it, I'm a tightwad. I dug a little deeper wanting to know what went bad with my resistor pack. Before using your posts and a schematic I found online, I was thinking about replacing the blower fan switch.
    With the resistor pack out, I was surprised to see the resistor pack had four resistors that were large coils of wire. Something peculiar caught my eye, there was one more component inside that didn't appear to be a resistor (omitted from the schematic). I remove the large heat shield from the resistor pack to expose the internal components. I ran some quick continuity checks with my ohmmeter. All of the resistors checked out fine. I check from the spade lugs on the pack and also at the end of the resistor leads. There appeared to be some minor corrosion internally where the resistors are attached internally.
    Centered between the four resistors was an interesting component that looked like a diode. Running a continuity check on that component I discovered it was 'OPEN'. I removed this component I got out my magnifying glass. The markings on this component are as follows.
    Microtemp
    KKKAJE
    G4A15
    128C ( 128 Celcius, 262 Fahrenheit....that's hot)
    This component is a thermal fuse made by a company call Thermodisc.
    http://www.thermodisc.com/productdet...p?ProductID=34
    Here is a data sheet link.
    http://www.thermodisc.com/loadMedia....&ReturnPage=14
    I was not able to find this readily available. So, I went to Digi-Key and I'm 'trying' a similar component. Another name for this component is a TCO, or Thermal Cut Out.
    This part costs me 98 cents, so I ordered three. UPS shipping is ~$6.61.
    ( Please, I'm not an expert, just cheap ). Another name for this component is a TCO, or Thermal Cut Out.
    Digikey part number: 317-1133-ND
    Description: THERMAL CUTOUT 128C 10A AXIAL
    Unit Price: 0.98000
    Troubleshooting: I've learned a few more things about the resistor pack. The schematic I worked from was a bit misleading, it appeared that the four resistors were in parallel, this is not correct. Why does the fan only work on HIGH when the resistor pack goes bad? The thermal fuse is the only path for current entering the pack. Why does your fan work on HIGH only? The pack is wired to bypass the thermal fuse and resistor pack completely.
    How does it work when the pack is good? Let's start on the HIGH setting. The resistor pack is bypassed and the blower gets 12V. When you switch it to the next lower setting, one resistor is added to the path of electricity going to the blower, slowing it down. Each time you select the next lower setting, an additional resistor is added to the circuit. At the lowest setting, all four resistors are in the circuit ( the lowest setting ).
    My guess is the lowest fan setting will generate the most heat ( all four resistors are in the circuit ) Why did the thermal fuse blow? I will have start with a just component failure. Time will tell.
    If you'd like a picture of the resistor pack with the thermal fuse, let me know. I'll email it to you.
    May 2008
    3
    coolinfo, thanks
    Jan 2013
    Victorville, CA
    6
    Quote Originally Posted by Gasman1979 View Post
    Hope that helps..
    if the resistor is bad, would that cause the motor to stay on constantly while vehicle is turned on?
  1. 02 grand caravan sport blows blower motor resistor
    By kkiml888 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-17-2014, 10:34 AM
  2. Cabin Air Filter 2003 Dodge Grand Caravan W/Dual AC
    By Mike in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-07-2012, 04:29 PM
  3. How to replace blower resistor: 2001 T+C
    By interstition in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-24-2012, 11:20 PM
  4. Where do I find 2001 Caravan Cabin Air Filter "COVER"
    By thetreichels in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-20-2007, 01:44 PM
  5. 2002 Dodge Grand Caravan Cabin air Filter location...
    By theboneskes in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-11-2007, 05:10 PM
