I just completed replacing my power window regulator this week. First remove the screw under the cap in the arm rest and the door handle area. There is also a screw underneath the map pocket toward the front. Then use a putty knife to carfully pry up the edge and pull. It will seem very hard but it will start to POP off. It is retained by about 9 or 10 panel clip. I bought a door panel removal tool but found the putty knife to work just fine. I would lower the window and reach the rod holding the door handle. It has a white plastic clip. reach under the clip and rotate it away from the rod. this should release it. disconnect the power window and lock connectors. You can also get some more info if you follow my post recently about the same problem. good luck
