'05 GC SXT Power Door Issues
Results 1 to 10 of 13
Thread: '05 GC SXT Power Door Issues
    Sep 2006
    517
    2
    The passenger-side power sliding door on my '05 GC SXT is not fully opening and closing. The door opens about three inches, and then stops. If I open the door all the way, then press the button to close it, it stops in the same place, about three inches from fully being closed. When I manually slide the door back and forth over the area where it stops, the door does not seem to be binding. It is below freezing where I am, but there does not appear to be any obstruction from ice. Everything else on the van works fine. Any thoughts as to what the problem could be?
    2014 Chrysler Town & Country 30th Anniversary Edition
    2014 Acura MDX
    1996 Mustang Cobra
    1995 Lincoln Mark VIII
    Dec 2003
    Hamburg, MI
    460
    Power Doors
    We had the same problem, once for sure, maybe twice. They replaced the door hinges if I recall correctly. I can check my service papaerwork later when I am at home. What ever they did, fixed the problem.
    Mike
    2004 Inferno Red, Anniversary Edition, Dodge Grand Caravan SXT, 3.8 V6
    2002 Mercury Sable LS, 3.0 24V Duratec V6
    Previously owned vehicles
    99 4WD Ford Explorer XLT, 4.0 SOHC V6
    86 Ford Mustang SVO, 2.3 FI, TC, IC, I4
    95 Ford Contour SE, 2.5 24V Duratec V6
    94 4WD Ford Ranger XLT , 4.0 V6
    89 Pontiac Grand Prix SE, 3.8 V6
    91 4WD Ford Ranger XLT, 4.0 V6
    81 Chevy Caprice Classic, 305 V8
    88 Ford Mustang 5.0 V8
    79 Ford Mustang Cobra 2.3 TC, I4
    75 Ford Elite 351W V8
    Dec 2004
    Toronto ON. CDN
    610
    Also do a search for similar issues that may involve a broken wire in the caterpillar tracking for the wires that carry power to the door from the vehicle frame. There has been alot of write ups on this very issue. Problems relate to door hinges as stated above and the fual flap sensor on the drivers side door even though yours is the passenger side door.
    KC.
    2012 VW Routan Highline w/ 3.6 L, 27,000 km.
    2001 Dodge Grand Caravan ES w/3.3, 250,000 KM and still going somewhere as it has been sold!
    Sep 2006
    517
    2
    ESADORNED - After reading these responses and mulling it over, I think you're right that it is a broken power wire in the caterpillar tracking. As the caterpillar bends while the door is opening, it must create a short right. I suspect that the short is right where the caterpillar bends when the door stops, which would stop power to the door motor. Do you have more info?
    2014 Acura MDX
    1996 Mustang Cobra
    Dec 2003
    Hamburg, MI
    460
    Door Stopping
    Does the door just stop or do your hear a springing sound when the door stops?
    Mike
    Sep 2006
    517
    2
    I don't recall here any noise when it stops. It just sounds like the door motor lost power.
    2014 Acura MDX
    1996 Mustang Cobra
    Dec 2003
    Hamburg, MI
    460
    No noise
    Then I agree, it might be a short. Ours you definatley heard a springing noise (as in sprung) when the door stopped.
    Mike
    Jan 2006
    Katy, Republic of Texas
    1,105
    Yea, I really need to find my volt meter to figure out if there is a short in mine too. It is getting really annoying.
    HERE is the thread with some pics that can get you started.
    Just a note: If you have five dollars and Chuck Norris has five dollars, Chuck Norris has more than you.
    Sep 2006
    517
    2
    Just an update...I wimped out and brought the van to the dealership. I told them that the problem is likely a short in one of the wires located the catipillar drive. They called back and said that the problem was with the wire harness (I presume we're talking the same thing) and would cost $274 to fix. I probably could have bought the part myself and fixed it, saving maybe half the cost.
    2014 Acura MDX
    1996 Mustang Cobra
    Dec 2003
    Hamburg, MI
    460
    EXT Warranty
    I am so glad I purchased an exended warranty on our 2004. It has paid for itself. Allthough the damn rear heat tubes werent covered by it, if it were I would really be jumping for joy.
    Cudd
  1. 05 Passenger side sliding door issues again.
    By n8ech in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-06-2013, 11:28 PM
  2. power steering issues!
    By rookie in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-16-2010, 06:25 PM
  3. door issues...again
    By emb2580 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 12-13-2007, 10:56 AM
  4. Keyless entry and door issues
    By naples34110 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-25-2007, 06:09 PM
  5. 2003 T&C Automatic Door Issues
    By bdzwonek in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-26-2006, 04:01 PM
