I lost almost all of my dash lights, instruments, and controls. Any help?
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: I lost almost all of my dash lights, instruments, and controls. Any help?
    Jan 2008
    2
    I have a 2003 Town and Country mini-van and I lost power to all my dash instruments yesterday.
    This includes my odometer, speedometer, fuel gauge, and all other dash lights. In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well.
    The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work. My head lights and heater come on automatically when the car is turned on, but cannot be controlled or turned off.
    I have had two mechanics look through everything and test the fuses and wires, but can't find anything wrong; aside from the fact that those things aren't powering up. The second mechanic suggested it may be the dash computer that has gone bad and that I would need to take it to the dealer.
    I've scheduled an appointment, but they can't get it in until Monday, so in the mean time, I'm wondering if anyone here has ever seen anything similar? If so, what was the cause? If it is the dash computer, how much could that cost to fix or replace?
    Any help or advice would be greatly appreciated.
    Thanks.
    Apr 2007
    San Diego
    5,171
    I'm not too familiar with 03s but, It sounds like either part of the Body Control Module (BCM) or the Forward Control Module (FCM) has gone on strike and it's effecting the data bus. Again, not familiar with the fuse arrangement but, look for a fuse labeled IOD or Memory probably in the Power Distribution Center (PDC - fuse box)) next to the battery. I want to say the PDC is called something else now. Not sure. Pull it out for 30 seconds and reinstall. This will reset the BCM and maybe the FCM. Disconnecting the battery will do the same thing. You could inspect the wiring and connections at the BCM on the fuse panel under the dash and the FCM attached to the PDC (i think). Wiggle the wire harness and see if anything comes to life.
    BCMs will cost $400+ at the dealership. Expect $600+ with labor. They can be had for less on the internet. I believe the FCM is a bit cheaper. Sounds like you're not using the dealership. Good move unless you are blessed with a dealership that has a good reputation. Try to find a shop that specialises in electronics. Better chance of having a mechanic who knows how to troubleshoot complex systems.
    Jun 2004
    rochester,ny
    731
    7
    Yeah before anything else reset the bcm via the IOD fuse getting pulled for a few minutes . Once in awhile this thing will get confused and stop sending signals to the equipment, after all it is a computer . Must be programmed by microsoft engineers . Think they should put control,ALT , delete keys in the vehicles.
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    33000 miles
    2008 Isuzu Ascender
    Midnight Blue Metallic
    93300 miles
    Dec 2007
    4
    did you loose hazard and signal lights as well?
    Jan 2008
    2
    Quote Originally Posted by mauger View Post
    Yes, I did.
    Thanks for the advice up above. The first two mechanices i took it to both reset all the fuses and checked the wiring and found that all the instruments were receiving power, they just weren't operating, which led them to believe it's a problem with the dash computer. So they said to take it to the dealer, which I've done and should find out on Monday if that's the problem or not.
    Jan 2008
    Southeast Arkansas
    432
    I'll bet money you are about to buy a new Body Control Module....That happened on the 02 T&C I had but all I lost were the dash lights and gauges...Mechanics are quick now a days to say the computer is bad (which is rarely the case) when they cannot figure out what the problem REALLY is...
    GASMAN :
    2008 Town and Country Touring
    Liquid Silver
    1995 Jeep Cherokee Sport with 2" lift on 31's
    MUD TOY
    Jan 2006
    Flint, MI
    75
    I have a similiar problem--just lost all the backlighting on my radio, climate controls, and power heated seat switches...all items WORK but backlights are out--is this just a fuse problem, and if so, is it BCM #1 or #2?
    Meet my 3.6L Fleet!
    Wife's: 2013 Chrysler Town and Country Limited (3.6L/62TE)
    Mine: 2011 Dodge Grand Caravan Crew (3.6L/62TE)
    My formers:
    2012 Chrysler Town and Country Limited (3.6L/62TE)
    2008 Chrysler Town & Country Limited ('08-'12) (4.0L/62TE)
    2008 Dodge Grand Caravan SXT ('09-'12)(4.0L/62TE)
    2003 Chrysler T&C Limited AWD ('04-'09) (3.8L/41AE)
    2001 Dodge Grand Caravan ES ('01-'04) (3.8L/41TE)
    1992 Plymouth Grand Voyager LE ('97-'01) (3.3L/A604)
    Jan 2006
    Flint, MI
    75
    WOW--did the ign on fuse trick and all is well...now just gotta fix the power seat motor....see my other post and please help!
    Meet my 3.6L Fleet!
    My formers:
    Dec 2008
    1
    IOD fuse pull fixes instrument panel lights
    I fixed the problem of all of the instrument panel lights being out by pulling the IOD fuse (15A fuse next to battery under the hood), waiting a few minutes, and re-inserting the fuse. Thereafter,all of the instrument panel lights on the dashboard lit up...
    Dec 2008
    1
    Thanks!!!
    I just bought a 2003 Chrysler Town & Country and the dash lights, radio control lights and temperature control lights were nonexistent, leaving me blind to my controls and speed at night. I looked for a fuse to no avail, and in the owner's manual it makes almost no mention of these lights at all. Finally I came across this forum and after pulling my IOD fuse for 60 seconds all is well.
    Awesome--thanks for saving me a ton of time, hassle and money!
  1. flashing lights on AC controls?
    By Batguano in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-02-2010, 02:16 PM
  2. Dash lights?
    By raquettelaker2 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-10-2010, 03:17 PM
  3. Please help. I lost the Dash board panel.
    By moneira in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-23-2009, 11:30 AM
  4. 98 voyager flashing lights on heater controls
    By tloughrin in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-22-2009, 03:47 PM
  5. Most dash lights are GONE! WTF???
    By PT_Sean in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-02-2007, 09:56 PM
