99 Caravan 3L noisy lifters
Results 1 to 10 of 12
Thread: 99 Caravan 3L noisy lifters
    Jan 2008
    3
    Smile 99 Caravan 3L noisy lifters
    Hi all, My 99 Caravan has 60,000 miles and in general has been pretty good, the usual repairs, brakes, 1 cv joint, speed control. I am religious on oil/filter changes and Tranny fluid changes especially on these trannys. I have always had noisy lifters on this vehicle starting at 30,000 miles just one or two and only on idle. Now it has gotten a little noisier and just anoying if I have to sit and wait for someone and have the car idle. Has any one else experienced this problem? I have tried engine flush and Wynns lifter aditive. no help.
    Thank you
    lenl
    Aug 2007
    16
    Leni, I have a 99 also and always thought the lifters were somewhat loud compared to other engines. I'm at 135k now with no problems. Always change the oil at 3k. Depending on your climate, you might try heavier oil or an additive like STP. Otherwise, I wouldn't worry too much about it.
    May 2006
    New Hampshire
    8,361
    Quote Originally Posted by jmiles1960 View Post
    Our 1998 has noisy lifters following a cold start as well. Errr, at least it used to, the secret is to find an oil filter with a very good Anti-DrainBack valve. The filter that works the best on our van is a Motorcraft FL-1A (available at both Walmart and Autozone, and I'm sure many other retailers), and starting from the second start after you spin it on, you will get absolutely zero valve train clatter.
  5. #4
    Nov 2005
    Fort Collins, CO
    3,895
    I could be wrong, but doesn't switching to synthetic oil also help dampen that noise?
  6. #5
    May 2006
    New Hampshire
    8,361
    Quote Originally Posted by Chrysler1924 View Post
    Nope, not even a little. Unless I miss my guess, the problem is that on the Gen 3 vans, the oil filter is tilted at about a sixty degree angle (just guessing here), and some how it seems that the anti-drainback valve on most oil filters is simply incapable of preventing the oil in the system above the filter from draining back into the oil pan. While I'm sure that there are other filters that are capable of keeping the valve train quiet following a cold start, the only one that I absolutely know for sure that keeps it quiet is the FL-1A Ford/Motorcraft filter.
    Filters that I know that DO NOT keep the valve train quiet:
    • Bosch 3500
    • Bosch 3402
    • Napa Gold 1515
    • Napa Gold 1348
    • Denso 150-1002
    Filters that I've run in the past but don't remember if they keep the valve train quiet:
    • Mobil 1 MI-204
    • Mobil 1 MI-301
  7. #6
    Jan 2008
    3
    Smile
    Thanks for the replys, The lifters are noisy on initial start and also after it has warmed up. When it is warm there are only one or two that are ticking. Quite annoying. I usually use a good quality FRAM filter and have been pretty religious on oil changes, also tried a flush and Wynns noisy valve additive. I think Wynns is a carbon buster to remove debris from the engine. anyway it didn't help much. I sometimes think the oil pressure might be a little low and the lifters are not getting enough oil. I dont think they are adjustable like the old chevys. I am going to maybe try a thicker additive. If this does not help I will probably replace the lifters.
    Thanks again.
    Long live Dodge
    Lenl
  8. #7
    Oct 2007
    Altamont, KS
    482
    14
    The "quality" fram filter might just be your problem. Fram are not necessarily a quality filter anymore.
    I would take Shipo's recommendation and try a motorcraft filter and see if things improve.
    Allen
    2005 T&C Touring. 3.8L Midnight Blue. 190K Still Runs
  9. #8
    Jul 2006
    Ottawa Canada
    404
    Exactly ... quality and Fram in the same breath is like saying military intelligence.
    At one time, they were good ... now just run of the mill.
  10. #9
    May 2006
    45
    Another vote that Fram is junk due to the glued paper end-caps. I am about to switch to the FLA-1 myself as I use it in another car, and it ups the oil capacity by about 1/2 quart.
    Some synthetic actually is nosier than Dino. Mobil 1 is noisy in some motors. Penzoil Platinum is the darling of group 3 synthetics, at the moment, over on Bob Is The Oil Guy due to good UOA numbers. It also is reported to be quiet. So if your thinking synthetic check that forum out.
    Marvel Mystery Oil added to Dino crank case oil will clean/quiet hydraulic lifters in a few days of use, if the problem is due to crud in the lifter. This is from personal experience on many motors over a 20 year period. I use it in everything I own, unless I have switched it to synthetic. It cleans up motors and actually makes them run smoother, again personal experience. That would be my first step to see if it quiets them down, as well as switching filters at the next oil change.
  11. #10
    Jun 2004
    rochester,ny
    731
    7
    3.0
    dont use mobil 1 , I tried this in my 3.0 when I had it and the thing sounded like a diesel after I put that in . Went back to Dino 10W-30 and it quieted right down . You also could try going thru the Auto-RX treatment , I have read that this will fix this problem too in a lot of cases .
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    33000 miles
    2008 Isuzu Ascender
    Midnight Blue Metallic
    93300 miles
  1. Noisy Lifters & Brakes
    By classiclistener in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-10-2008, 11:53 PM
  2. Timing Belt / Noisy Lifters / Oil Pump
    By JimmyM in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-29-2007, 01:25 PM
