2004 Caravan Instrument Panel Bulb
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 42
Thread: 2004 Caravan Instrument Panel Bulb
    Dec 2007
    Pacific Northwest
    261
    The bulb that lights the fuel gauge has burned out and the dealer has quoted $300 to replace it. Is it possible to replace it myself?
    May 2006
    300
    6
    Yes, this is something you can do yourself, and very easily. simply remove the cluster and change out the bulbs, (do them all as they tend to all go at once anyway). Now for the downside. The Bulbs are PC74, meaning that they have a special base on them so they will screw in. You can not get them at the auto parts store, you have to get them at the dealer, I believe for around $5 each. Another option, which is what I did, is to go to www.superbrightleds.com and order from them. If you get the white LEDS, you will have true blue gauges, not the green. (if you like the green, go with a yellow or green LED) If you need more specific information let me know. Hope this helps.
    Present:
    2016 Dodge Grand Caravan SE Plus
    2010 Chrysler Town & Country Touring 4.0
    2004 Chrysler 300M
    Past:
    2011 Dodge Grand Caravan Express (Blown Transmission 7-15, 122K)
    2006 Dodge Caravan SXT (sold 6-11)
    2005 Dodge Grand Caravan SXT (traded 4-10)
    1994 Plymouth Grand Voyager Conversion Van (R.I.P)
  4. The Following User Says Thank You to Concorde300M For This Useful Post:
    FamilyGuy76(03-08-2011)
  5. #3
    Sep 2006
    517
    2
    I literally changed my gauge bulbs just 15 minutes ago. Here are the steps:
    1. Remove the two screws on the inside top of the dash bezel.
    2. Remove the lower portion of the dash bezel by gently prying it up. This is the black piece over the steering column.
    3. Underneath the lower portion of the dash bezel, there are two more screws that hold the main piece of the dash bezel. Remove these.
    4. You can now remove the dash bezel. It is helpful to shift the gear selector lever out of park to give you more wiggle room.
    5. Remove the four screws the hold the gauge cluster in place.
    6. Tilt the gauge cluster forward. Remove the wire clamp so that you can remove the cluster. This took some wiggling back and forth.
    7. On the back of the cluster, you can remove the bulbs by gently twisting them with pliers.
    8. Replace the bulbs with new. The bulbs are PC74 and you can order them from rockauto.com. I replaced all eight.
    9. Reassemble doing the reverse of above.
    I cannot believe you were quoted $300. It's $10 worth of parts and 20 minutes of time.
    2014 Chrysler Town & Country 30th Anniversary Edition
    2014 Acura MDX
    1996 Mustang Cobra
    1995 Lincoln Mark VIII
  6. The Following User Says Thank You to BlackOnBlackCobra96 For This Useful Post:
    tooltime(02-11-2016)
  7. Remove Advertisements
  8. #4
    Dec 2004
    Virginia
    4,029
    You can also get the bulbs at most auto parts stores, without the gray plastic housing that twists in. They're kind of a pain to get out, but it's not too hard to do. Each pair should set you back less than $3, so less than $12 for all 8...and do replace all 8. If you don't, one of the other bulbs won't work when you put the cluster back in.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
  9. #5
    Dec 2007
    Pacific Northwest
    261
    Thanks to everyone for their advice. I will replace the bulb (all of them) this weekend.
    _________________________
    2004 Caravan SXT
    1996 Caravan LE
  10. #6
    Dec 2007
    Ajax. ON.
    43
    Quote Originally Posted by BlackOnBlackCobra96 View Post
    Very helpfull guide as I also need to replace a bulb in the console.
    '97 Dodge Grand Caravan 3.8 ES
  11. #7
    Oct 2007
    22
    Smile Replace PC74 with #74 bulb
    To replace the PC74 simply break the old bulb out of the grey housing and gouge out the glass stub with a jewelers screwdriver. Be careful to move any wire stubs to each side and verify that the socket without a bulb does not have a short (No continuity).
    Then simply insert an off the shelf #74 bulb. Check for continuity between the two contact tabs or apply 12v to them to verify operation.
    I have done this several times on three different caravan/T&C's with no problems.
  12. #8
    Mar 2011
    2
    This is a great post, and I used it today with success. One thing I did not do was to disconnect the wire harness. I could not get it off, and found that I could replace all of the 8 bulbs with the harness still intact. This required a little finesse to reach the bulbs, but was totally possible. Thanks for your original guidelines. Saved me a bundle. Best regards,
  13. #9
    Sep 2010
    123
    This is a good thread. There needs to be a 4th GEN FAQ on common issues and fixes.
    Some questions for the bulb gurus here. On my van it looks like the gauge faces around the 3 o'clock position are dim. Are there bulbs in this area, or is it purposely dimmer to discourage triple digit driving at redline? Does anyone know on a manual 3-zone temp control what bulbs are behind the temp sliders? Also behind the rear defrost button? Last one for now, is the hazard button supposed to be illuminated? Seems like it should be.
    Thanks in advance,
    TL
    '03 Town & Country LX 3.8
  14. #10
    Dec 2004
    Virginia
    4,029
    It sounds like you have two bulbs out. The speedometer and the tachometer are each illuminated by three bulbs.
    My recommendation would be to remove all eight bulbs, so you won't have to do it again.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
  15. The Following User Says Thank You to mmahamm For This Useful Post:
    06DGC(10-31-2013)
  1. 1996 Grand Caravan, Instrument panel non-functional
    By rknapp in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-01-2010, 09:06 PM
  2. Help!!! No Instrument Panel
    By minngo4s in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-23-2009, 10:08 AM
  3. 05 Grand Caravan instrument panel flashes
    By onmy4thminivan in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-15-2008, 07:32 PM
  4. 2004 Limited, instrument panel lights
    By VFRbeliever in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-16-2007, 05:36 PM
  5. Instrument panel
    By chr1997 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-20-2005, 07:31 AM
