OBD-II code P1494 Leak Detection Pump Switch or Mechanical Fault -what does it mean?
Results 1 to 4 of 4
Thread: OBD-II code P1494 Leak Detection Pump Switch or Mechanical Fault -what does it mean?
    Sep 2003
    Colfax, NC
    172
    2
    Do any of you know what OBD-II code P1494 means?
    I found a code list on another website that translated P1494 as "Leak Detection Pump Switch or Mechanical Fault". LOL I see the words but they mean nothing to me.
    Any suggestions?
    2008 Mazda Tribute i sport 5-speed
    2007 Infiniti G35
    2003 Chrysler Town & Country eX
    1995 Saab 900 SE Turbo convertible
    1992 F-150 XLT
    2000 John Deere 4410
    Oct 2007
    Petawawa, Ontario
    312
    (Stolen from : http://en.allexperts.com/q/Chrysler-...rysler-t-c.htm)
    "Leak detection pump switch or mechinical failure"
    You were in the area of the ldp solinoid.Its a electrical switch with 2 wires and 2 vacuum lines connected to it.I would follow those lines and make sure the one that goes to the manifold is still hooked up and that you have vacuum to the solinoid.The other line makes its to nvld which is mounted below the steering gear.But first it will go under the air cleaner housing.It will have a plastic or steel line with a rubber hose juction in a couple of places.The rubber hoses will crack and leak and could be the cause of your problem.But retrace your steps to make sure you didn't knock any lines loose.
    (end)
    Hopefully this helps..
    HyperFox
    Proud to serve my country! Support your Canadian Troops!
    2007 Dodge Grand Caravan Stow-N-Go
    Visit my blog: http://hyperfox2007.blogspot.com/
    Sep 2003
    Colfax, NC
    172
    2
    Quote Originally Posted by HyperFox View Post
    (end)
    It does...........I looked at your source. They got their code by replacing the ps reservoir. That's what I did. So I'll go look at the same area and see if I left something unplugged.
    thanks,
    Mac
    2007 Infiniti G35
    1992 F-150 XLT
    Oct 2009
    Rapid City, South Dakota
    1
    I got the Code #1494 on my 2001 Dogde Ram after changing my air filter. Did I knock something loose or not reconnect something?
  1. P1495 Leak Detection Pump Solenoid Circuit
    By universaltek in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-15-2010, 11:36 AM
  2. Leak detection pump???
    By F BULLDOG in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-17-2010, 03:37 PM
  3. 2001 caravan leak detection pump
    By monte in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-31-2008, 02:50 PM
  4. Code P1494 Leak Dectection Pump
    By attdnt in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-05-2007, 12:37 AM
  5. Check engine soon code P1494
    By cchovaz in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-02-2006, 06:22 PM
