Outside air temp sensor location?
Results 1 to 5 of 5
Thread: Outside air temp sensor location?
    Mar 2004
    1
    My wife just brought home a new outside air temp sensor that the dealer just sold her to fix the temperature error in the overhead display of her 98 Voyager. They told her the sensor is located "behind the grill". Does'nt that apply to 99% of the vehicle? Can someone tell me where to find this sensor?
    Sep 2003
    870
    'behind the grille' would be under the hood at the very front. The grille they are referring to is the thing between the two headlights.
    1999 Dodge Caravan 3.0 - 180 000Kms as of March 11th, 2004
    1987 Chevrolet Chevette - Inline 4 - 1.6l - 122 000 Kms
    Both Great Vehicles, Reliable, and Perfect.
    Dec 2003
    Eau Claire, WI
    2,799
    I don't have a van of that generation so I don't know for sure, but the temp sensor would have to be close to the grille, probably immediately behind it. If it were any more than a few inches away from the grille, the sensor would get warmed by the heat from the engine and show an inaccurate reading.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
    Jul 2003
    High Ridge, Missouri
    4,760
    Here is how the 2002 mini service manual says to get to it. This is on the new gen mini, not yours, but may work. You have the new one in your hand so you know what you are looking for. Check it out.
    AMBIENT TEMP SENSOR
    REMOVAL
    (1) Disconnect and isolate the battery negative
    cable.
    (2) Raise and support vehicle on safety stands.
    (3) From behind front bumper fascia, remove
    screw holding sensor to radiator closure panel.
    (4) Remove sensor from vehicle.
    INSTALLATION
    (1) Position the sensor in the vehicle.
    (2) From behind the front bumper fascia, install
    the screw holding sensor to radiator closure panel.
    (3) Connect the battery negative cable.
    Avatar: EconoVoyager Concept
    Sep 2003
    870
    Nice Info DSMLVR :tup
  1. Location of Engine Coolant Temp (ECT) Sensor
    By B-5 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-20-2016, 05:23 PM
  2. Coolant Temp Sensor
    By gsmagnum in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-18-2010, 10:39 PM
  3. Temp sensor install
    By KillaGrn in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-07-2009, 11:12 PM
  4. Trans temp sensor/mount location?
    By RED04DGCLE in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-19-2008, 08:10 PM
  5. Where can I get an outside temp sensor?
    By rico in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-31-2007, 09:10 AM
