Back-Up lights not working.
Results 1 to 8 of 8
Thread: Back-Up lights not working.
    Mar 2005
    Lenoir,N.C.
    75
    My back -up lights are not working. Everything else seems to working fine.
    Tail lights,brake lights,and tag light works.
    The fuse is not blown,nor are the bulbs (but where replaced anyways).Any other suggestions?
    hope
    1998 Dodge Caravan 3.0 76,000 miles (new engine)
    1996 Toyota Truck
    Mar 2007
    2,964
    Check voltage at the reverse light socket while in reverse...
    Possibly: Is the shift-position dash indicator lamp for "Reverse" illuminating while in reverse?
    If not, I'd guess the transmission range sensor (TRS) - which communicates gear position to the TCM. It requires removal of the trans valve body to get at. (ATF+4 fluid and filter, while you're at it...)
    -Jim
    Nov 2005
    Fort Collins, CO
    3,895
    Bad wiring probably, or perhaps a dirty electrical contact in the light housing on the reverse bulb.
    Sep 2007
    3
    let me know what you find out my backup lights on my 97 caravan quit to fuse bulbs are fine there is just no power to them
    May 2006
    Alberta
    9
    It could be the neutral safety switch/ backup light switch on the transmission. My backup lights wouldn't work( checked all connections, switched light bulbs, checked voltage at the bulbs), finally got under the van and cleaned the plug, they worked for a while, then died again, final solution was replacing the transmission, now I have no problems. I suggest you check the switch plug, and replace if you can ( i think it was about $15.00 CDN at dealership).
    Jan 2008
    2
    The Transmission Range Switch detects Reverse and powers the Backup Light relay in the relay box located to the right side of the battery as viewed from the front. I suggest that you check or swap out the relay. You also could jumper the female terminals in the relay box to supply power to the lights and and see if they come on (make sure you get the right terminals!).
    Jan 2008
    1
    one vote for the neutral safety switch. It's cheap and quite straitforward to change if your van has 3-speed trans.
    It's on the Transmission. All you need is 2" socket that's it.
    Disconnect the cable attatched to the switch by simply pulling it and unplug the switch using 2" socket.
    and replace it with new one. It costs $18 at Canadiantire.
    Good luck.
    Sep 2007
    3
    try unplunging the neutral safety switch/ backup light switch and cleaning the contacts worked for me
  1. Resting fuse for non working back lighting on Auto Climate control
    By 2002es in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-11-2009, 11:33 AM
  2. 2 questions. Cluster lights & back lite window switch..
    By barbarino in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-31-2009, 02:30 PM
  3. Replies: 13
    Last Post: 03-11-2009, 05:08 PM
  4. 1992 Acura Integra Tail lights/Instrument lights quit working.
    By sideburns2009 in forum The Fireplace
    Last Post: 03-02-2009, 12:18 AM
  5. Driver Side Parking Lights-Front and Back
    By johnny1509 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-30-2005, 05:24 PM
