Page 1 of 15 1 2 3 11 ... LastLast
Results 1 to 10 of 144
Thread: Power Steering Noise Fix - Changed the Reservoir
Share/Bookmark
    Sep 2006
    460
    Loud screeching sound plagued my '01 Voyager 3.3limmediately after startup. Although the noise would go away after few minutes, it sounded hideous.
    I tried some suggestions from this board, such as swapping the starter under the theory that the starter gear was not retracting. Changing the serpentine belt also made no difference. Another suggestion that marginally helped was siphoning and replacing much of the fluid in the power steering reservoir.
    After digging deeper, I learned that the reservoir has a screen within it that tends to clog. I purchased a new one from Chrysler for less than $30, along with high-end power steering fluid, and replaced it. Now, the noise is completely gone.
    Here is how to change it. The reservoir is on top of the engine and is very accessible. To swap it, siphon out as much fluid as possible. You can use a turkey baster, but remember that turkey-day is around the corner. Next, remove the two bolts on top of the reservoir with an 8mm socket. Then use pliers to remove the two hoses clamps connected to it. There were two unrelated tubes that were in the way, which pulled off by hand and made clearance easier. There is one bolt underneath the reservoir that needs to be loosened (not removed) with a 10mm socket. Removing the two hoses from the reservoir took penetrating oil and muscle, even with the clamps removed. Overall, it took about 45 minutes and was not too difficult. I now consider replacing the reservoir as a maintenance item for higher mileage vans. Hope this helps.
    2005 Grand Caravan SXT 3.8L
    2001 Chrysler Voyager 3.3L Flex Fuel (210K miles and running strong)
  2. #2
    Nov 2007
    Texas
    2
    I have a 2002 Town and Country with 108,000 and I am having a "whine" sound on cool mornings. I took it to my mechanic, who told me about a recall, because his wife as a Dodge 2002 minivan. I can't find anything about this recall. Does anybody know anything about this?
  3. #3
    Jul 2005
    414
    Quote Originally Posted by nkg406 View Post
    For all you folks looking for the various recalls and Technical Service Bulletins, go to this website, see the little red letters under the top ?
    http://www.chryslerforum.com/forumid_18/tt.htm
  4. #4
    Jul 2005
    NJ
    1,287
    That looks like a complete list, but has only the summaries, like any other free
    source of this information.
  5. #5
    Dec 2004
    Virginia
    3,615
    10
    Quote Originally Posted by BlackOnBlackCobra96 View Post
    ...I purchased a new one from Chrysler for less than $30, along with high-end power steering fluid, and replaced it...
    What exact high-end power steering fluid did you purchase? My understanding is that, starting in 2002 (?) the recommended fluid is now ATF+4. Don't know if it is retroactively specified for earlier years.
    Michael
    Centreville, VA
    Currently driving:
    2005 Dodge Grand Caravan SXT, 75K mi.
    Former owner of:
    1988 Dodge Caravan SE, 2.5L I4 (1988-1995, 99K mi); 1995 Plymouth Grand Voyager SE "Rallye", 3.3L (1995-2004, 169K mi); 2003 Grand Caravan Sport, 3.8L, (2004-2008, 106K mi)
    Other vehicles:
    2002 Lexus RX300 (Gold), 138K mi; 2005 Hyundai Elantra GT (Blue), 38K mi
  6. #6
    May 2006
    New Hampshire
    4,654
    Country
          shipo's Country Flag is:  United States
    4
    Quote Originally Posted by mmahamm View Post
    While ATF+4 may not be retroactively specified for earlier years, the steering rack on our 1998 was getting a little noisy late last winter. In an effort to cure the noise, I performed the "suck the reservoir dry and refill with ATF+4" thing a couple of times, and, noise gone. That was some 15,000 miles ago and it still drives perfectly noise free. Given that the van had 135,000 miles on it at the time I didn't figure I had too much to lose if the fluid replacement didn't work.
    1998 DGC Sport 3.8 (Gone but not forgotten)
    2003 DGC ES 3.8
    2009 Mazda3 i Touring (5-Speed)
    1998 Chrysler T&C LXi 3.8 (the former flybyy-mobile)
  7. #7
    Mar 2007
    Western Taxachusetts
    429
    4
    Here is a picture of the label on a gallon of ATF+4 indicating power steering approval for post 98 and later.
    Frank
    99 DGC Sport 115900 mi
    07 T&C SWB 7200 mi
  8. #8
    Jan 2005
    Fayetteville, NC
    9,185
    Country
          Hokiefyd's Country Flag is:  United States
    5
    Also evidence that the fluid truly IS designed to be a "fill for life" fluid under normal circumstances.
    '11 Toyota Camry | 2.5/6AT | Sandy Beach | 4k
    '07 Chrysler T&C | 3.8/4AT | Cognac Crystal | 43k
    '97 Dodge Dakota | 5.2/4AT | Emerald Green | 179k
  9. #9
    Jun 2005
    KS
    1,294
    1
    Quote Originally Posted by Jason View Post
    "fill for life" = *until it fails from lack of service*
  10. #10
    Sep 2006
    460
    Quote Originally Posted by 05SXT View Post
    After changing my resevoir with fluid that last 190K miles, it didn't seem like the fluid went bad. It appeared that foreign particles within the fluid clogged the screen within the resevoir and created me issue. I suspect that if there was filter to catch these particles (perhaps the screen within the resevoir IS the filter), the fluid would last for the life of the vehicle. I'd still service it, because the fluid does get contaminated.
  1. 2004 T&C Power steering noise
    By dwp30 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-21-2008, 02:15 PM
  2. 05 caravan with power steering noise
    By hammer in forum Introduce Yourself and Your Minivan
    Last Post: 01-29-2008, 08:20 AM
  3. 02 EX: Power Steering Noise - RESOLVED!
    By Omaha_GC in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-22-2007, 03:38 PM
  4. Power Steering Noise???
    By wndrwmn67 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-12-2007, 08:02 PM
  5. Remove 2003 power steering reservoir
    By KCMike in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-11-2007, 03:35 PM
  • You may not post replies
