Sliding door hard to open
Results 1 to 10 of 12
Thread: Sliding door hard to open
    Oct 2006
    110
    15
    The left power sliding door on my 2007 T&C is much harder to open than the the right when you open and close it manually. I had this problem on my 2003 before I traded it in and I was hoping this issue was addressed and fixed by Chrysler by now. The good thing is my 2007 is under warranty. Does anybody know if it is still the motor clutch causing this problem in the 2007s? What are the dealers doing to fix this problem when Chrysler is paying for it?
    Dec 2004
    Virginia
    4,029
    Best way to find out is to get it fixed. Your service invoice will list what they did.
    Michael
    Centreville, VA
    Currently driving: 2015 Jeep Cherokee Trailhawk
    Former owner of:
    2005 Dodge Grand Caravan SXT, 129K mi.; 2008 Nissan Quest, (2008-2010, 25K mi); 2003 Grand Caravan Sport, 3.8L, (2004-2008, 106K mi); 1995 Plymouth Grand Voyager SE "Rallye", 3.3L (1995-2004, 169K mi); 1988 Dodge Caravan SE, 2.5L I4 (1988-1995, 99K mi);
    Oct 2006
    110
    15
    I did take my T&C into the dealership yesterday for this problem. They replaced the sliding door motor and that took care of the problem. I guess I'm just disappointed that this seems to be a recurring problem since we had the same issue on our 2003 T&C but traded it in without having it fixed. I have 11,000 miles on my 2007 T&C right now. I will be paying very close attention to the operation of the sliding doors before my warranty ends.
    Dec 2004
    Toronto ON. CDN
    610
    Good to know. Our 2001 GCV still has the stiff left door. I would have to replace it myself as stealership rates might be a little expensive. The labour rate at our dealer now exceeds $100.00 per hr. Feel a little pricey, you bet.
    KC.
    2012 VW Routan Highline w/ 3.6 L, 27,000 km.
    2001 Dodge Grand Caravan ES w/3.3, 250,000 KM and still going somewhere as it has been sold!
    Nov 2005
    Fort Collins, CO
    3,895
    (I don't have a fourth gen, so forgive the question)
    Are the power slider motors supposed to disengage when the sliding doors are opened manually? Or are they simply supposed to "free wheel" in a neutral state unless power is required?
    Jan 2006
    Katy, Republic of Texas
    1,105
    I never knew how easy the doors were supposed to open manually.
    I opened the doors on my brothers '01 with manual doors and almost ripped them off. Both my doors are stiff, so I don't know how they are supposed to be?
    Just a note: If you have five dollars and Chuck Norris has five dollars, Chuck Norris has more than you.
    Jun 2004
    rochester,ny
    736
    7
    Yeah thats why I would never consider power sliders , too much to go wrong . I want a simple vehicle and i have never had a problem with the manual sliders.
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    48000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Dec 2004
    Toronto ON. CDN
    610
    The manual doors are definetly free'r float'in than the electric sliders. The passenger side on ours is easier to move then the drivers side, but the drivers side has always been an issue on ours. For manual operation, I believe the clutch on the motor disengages the motor and lets you freewheel it. This clutch is the one that seizes, info from previous threads, and you are dragging along the motor and possibly little gearbox and drive cable when opening manually that all contribute to the very stiff feeling. My wife can barely open the drivers side manually. Now our passenger button for the drivers side is starting to operate intermitt. The overhead console one works fine.
    KC.
    Jan 2005
    Fayetteville, NC
    9,436
    Having had a 2003 with manual sliders and a 2007 with power sliders, I can also compare directly.
    Both sides of our 2007 operate with about the same resistance when closed manually. They have probably 50% more resistance than the manual sliders do. Even though the motor is disengaged, the drive system (gear constantly in mesh with the toothed rack) is always "engaged", so there's some added resistance there. I don't consider it to be too much more (when operating correctly). There's still enough "free wheel" for the door to try to slide closed on its own when parked down a hill (after it's disengaged from the "lock").
    The power liftgate closes manually with exactly the same resistance compared with our 2003's manual 'gate. The drive mechanism must be a little bit different.
    While this system does have its faults, I appreciate that Chrysler engineered-in a clutch system like they did. On other vans with power doors (such as the Honda), you CANNOT close it manually. You MUST let the motor close the door. When you try to pull it closed, it resists you and closes on its own (slow pace). This can be a detriment when there's driving rain and you just want that door closed NOW.
    Incidentally, although our van has power doors and 'gate, I never use them. My wife does all the time, and appreciates them.
    Jan 2005
    189
    Ok this is important as I know an easy fix for the door (well maybe not that easy, but it's free)
    First take the top (above glass) panel of the door off, then the biggest one ( dont bother with the one that has the handle). Ok now take the black mat off the door(it doesn't have to be completly off). Take out the retainer clip that attached the shaft to the motor. Pry of the 4 white clips (don't worry they are durable). Take out the motor and unscrew the star shaped screws ( you need the star screwdriver to take them off). Disconnect the black wire on the side of the motor btw. Once you unscrew the screws take off ONLY the part where black wire is coming from, don't take the whole thing off as it will be kind of hard to aling the gears back up. Clean the elecromagnetic clutch (the disc with 4 slots, the thing it binds to and the solenoid). Make sure they are very clean (I cleaned it with alcohol). Put it back and if you accidentally took of the gear box ,dont worry it will take sometime to put it back but no damage will occur. The putting back part is the reverse of the disassembly.
    Any questions or clarifications, just post bakc here.
    Ps the reason why they replace the motor is that they essentially replace the clutch and that solves the problem.
  1. Power Sliding Door Won't Open
    By gtlou in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-04-2011, 06:46 PM
  2. Sliding door frozen won't open
    By ancamo in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 10-16-2009, 03:30 PM
  3. 02 T+C pass rear door hard to open
    By travis in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-12-2008, 09:24 AM
  4. sliding door won't stay open
    By lorive in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-01-2008, 12:09 PM
  5. '00 Chrysler T&C AWD Sliding Door Won't Open
    By road robert in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-25-2007, 09:32 AM
