Strange noise from under the hood.
Results 1 to 9 of 9
Thread: Strange noise from under the hood.
    Aug 2007
    12
    I just noticed a strange sound thats possibly coming from my tansmission in my 96PGV 3.3L.
    Its not the normal buzzing sound of the solenoids. Its completely random, doesn't make it when i hit a bumb, floor it, or the tranny shifts. The bestway i can describe it as someone draging there fingernail over a metal comb if that makes any sense.
    Any ideas?
    Dec 2006
    1,106
    31
    Are you sure this isn't coming from the drivebelt end of the engine? There is a very common noise that sounds like a bell ringing or crickets chirping. I've seen some debate as to whether it is a bearing going bad or resonance from the belt slipping very slightly side-to-side across, say, the water pump pulley.
    - G
    1998 Grand Voyager @333,000mi, 3.3L FFV V6
    Aug 2007
    12
    the problem is its so random, that i can't duplicate it, but when i have my window down it sounds like its coming from the tranny. The acc belt is still in good shape.
    Theres no change in performance when it does it, im just uber paranoid when it comes to the transmission lol
    Jul 2006
    96
    Could I be far off and that noise is the engagin/disingaging of the ABS? the sound you describe fits..
    Aug 2007
    12
    wll it doesn't just happen when im braking so the abs must be going out if thats the case. Tomorrow i'll go take it out behind base and "purposely engage" the ABS and see if its the same sound
    Aug 2007
    11
    My '96 GC with 100,000 on it recently had noise similar to what you describe (rear of block/front of tranny) and was diagnosed with failing front tranny pump, FWIW.
    Jan 2007
    106
    I noticed today that my '97 Grand Voyager 3.3 was making a noise similar to what you guys are describing. Mine does it with the van running in drive or reverse with my foot on the brake. Sounds like two pieces of metal grinding. The fluid looks fine and doesn't smell burnt. Any advice would be great.
    Nov 2008
    DeSoto County, MS
    2,926
    You could also remove the ABS relay or fuse. That would disengage the ABS system if the ABS pump were to be malfunctioning, it would cut power to it. Just to eliminate that as the culprit, unless it is of course.
    Mar 2007
    2,956
    I get the "comb" noise occasionally ('02 DGC SE 100kmi) - only when in reverse, and then (usually) only with the LF wheel/strut higher than RF. Specifically, up on a small berm or curb, when I retrieve mail from the curbside box, then reverse back to our driveway.
    Not ABS related, far as I have discerned - unless it's the tone wheel rubbing. ABS functions fine...
    -Jim
  1. Strange noise
    By arap3000 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-29-2010, 08:52 PM
  2. 2001 T&C hood rattle noise at hood hinge. TSB?
    By Dave Maher in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-29-2010, 11:00 PM
  3. strange noise
    By pops in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-12-2009, 06:15 AM
  4. strange transmission? noise
    By flybyy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-25-2005, 07:08 PM
