Diagnostic connector pin-out?
Results 1 to 10 of 10
Thread: Diagnostic connector pin-out?
    Apr 2007
    Bowral, NSW Australia
    189
    1
    Calling for help, I am trying to find the correct wire on my 97 Voyager's diagnostic connector. I want to connect the RKE pin to ground so I can program an additional key fob.
    Does anyone know exactly which pin I should be grounding? (Another post says it is a GREEN wire on Pin 1, but my pin 1 is empty. There is a Red wire on pin 16)
    Alternatively, where is the Remote Key Entry module located? I've been looking but not finding it behind my glove box.
    Any help gratefully accepted!
    Regards,
    Andrew
    1997 Chrysler Grand Voyager Ltd 3.3 204,000km
    Previous:
    Ford Falcon S/W 1996
    Volvo 244 GL 1981
    Holden Commodore VL S/W 1986
    Triumph 2500TC 1974
    Ford Transit 1975 (My first car!)
    Work cars:
    Current: Nissan Dualis 2009
    Previous:Holden Astra 2008, Holden Commodore S/W 2006
    Feb 2004
    664
    I see you are in Oz.. where was your van built? RH drive?
    Chopper Reid can help if you get it wrong.. ha!
    haaaaden the (*& up..
    2006 DTS performance
    2005 Pacifica
    2001 SSEi Bonneville
    2001 RAM Conversion Van
    1997 Magna
    www.femint.com
    Apr 2007
    189
    1
    Still looking for the RKE module/program enable..
    Hi, can ANYONE help me find the Remote Keyless Entry module in my 96 Chrysler Grand Voyager? Yes, it is a Right Hand Drive model.
    The 16-pin Datalink connector is black in colour.
    I need to ground the "Program enable" wire, so that the Key fob can be programmed.
    Apparently this is a green wire that also runs to the Datalink diagnostic connector. But can anyone tell me which pin on the connector it should be? I don't want to destroy anything!
    Please, please help! (you are my only hope!)
    Andrew
    Previous:
    Volvo 244 GL 1981
    Triumph 2500TC 1974
    Work cars:
    Jun 2007
    213
    For a 2000 model, LH drive you have to remove the instrument panel top cover. The box is located by a duct and near the instrument panel.
    Apr 2007
    189
    1
    Thanks for your help!
    I will take off the top panel cover & see how I go. Thankyou so much for the advice!
    Any idea which wire is the programming wire? My haynes manual has a circuit diagram for Remote Keyless Entry on 96 & 97 models with a connection that goes to the BCM labelled "RKE Program Sig", and a colour code of "GRY/BLK". There is another wire labelled "RKE Interface" that also goes to the BCM. This one is labelled LT GRN/RED on the diagram. There is a 3rd connection from the RKE labelled "BLK or BLK/LT GRN" which terminates on the "Instrument panel ground block". There is also a 4th wire from the RKE labelled "PNK" which goes to the "Fused B+" connection on the BCM. (This diagram is on page 12-42 of my Haynes manual) I guess my final question is: do I ground the light green/red wire, or do I ground the Grey/Black wire? Or do I simply connect a jumper between both of these (RKE Program Sig and RKE Interface) to do the programming? Once again, I really appreciate your advice and help with this. (Without access to a programming tool I am hoping this "grounding" of the RKE will enable the programming of a spare keyfob I have been able to buy off Ebay.) Last week the keys got locked in the car by mistake - I notice that if you open the hood while the keys are in the ignition, the vehicle anti-theft system seems to automatically lock the car after a period of time! ....so you can understand my passion for programming the RKE unit! An additional set of keys & keyfob seems to be a good idea.
    I am just hoping that some of you good people can advise me on the best way to go about it.
    I am planning to remove the upper dash panel and try to find the RKE box & wires next weekend, and hookup a toggle switch to help me do the programming job.
    Thanks again for the advice. Any more is very welcome!
    Regards
    Andrew
    Previous:
    Volvo 244 GL 1981
    Triumph 2500TC 1974
    Work cars:
    Jun 2007
    213
    The wires you list don't match my 2000 manual. Are you sure this is a valid way to reprogram the module?
    Feb 2004
    664
    here is a link to when I had the same problem..
    http://forum.chryslerminivan.net/showthread.php?t=547
    here is another link to the TSB, you probably dont have this type, but maybe?
    http://dodgeram.info/tsb/2002/08-007-02.htm
    If you have EVSII, I think there will not be a green wire... use the first link.. or this one...
    http://forum.chryslerminivan.net/sho...hlight=keyless
    This link for a 97 references a gray / black wire..
    good luck.. when you sort it, post a photo or six..
    2005 Pacifica
    1997 Magna
    www.femint.com
    Apr 2007
    189
    1
    Fixed!
    It all worked as described - connected the switch up to the RKE wires & was able to program another fob. Thanks to all for your help. Any questions welcome.
    Regards,
    Andrew
    Previous:
    Volvo 244 GL 1981
    Triumph 2500TC 1974
    Work cars:
    Jun 2016
    3
    Quote Originally Posted by andrewhgee View Post
    Regards,
    Andrew
    Hi Andrew,
    I'm in NZ and we have the exact same model Voyager as you ('97 Grand Voyager, 3.3L).
    You've confirmed you have connected a switch up to the RKE and programmed your 2nd remote.
    However, you haven't explained the process.
    Could you please explain in detail, so I can also do the same?
    Thanks,
    Scott in NZ
    scottbaileynz@gmail.com
    Jun 2011
    SE Michigan
    4,361
    Welcome to the site Scott.
    Unfortunately this thread from Andrew is 9 years old and he has not been active on this site in over 5 years.
    Hopefully another member will see this and can help you out.
    2013 TC Limited Black/Graystone Custom ordered 5/13
    Luxury non Stow & Go buckets, Tow and almost everything else. Lifetime Max Care warranty. Driven to 36 states so far.
    1994 Grand Caravan SE Sport, 3.3L, 351,000+ miles and counting. Original engine and trans. Bought it new and have driven it to 48 states. Now my daughters daily driver.
  1. What is this connector?
    By 95shelbyvoyager in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 11-01-2012, 10:42 PM
  2. Diagnostic hardware *New offer*
    By AzTraveller in forum For Sale
    Last Post: 12-09-2008, 07:53 AM
  3. diagnostic codes??
    By wolly1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-10-2007, 06:30 PM
  4. Mystery Connector
    By geezer49 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-12-2007, 07:44 AM
