I've got a 2001 SE and the check engine light came on a few days ago. I checked for codes as was described on this forum and came up with P0442 & 0445. I know this is related to the Evap system. Funny thing is that I had the engine light come on two months ago and the dealer mentioned that it was a small EVAP leak. They couldn't find where it was leaking and I guess they reset the codes since the engine light didn't come on for two months. Now I'm back at square one! I intend on checking my vacuum hoses, but was wondering how I clear out the codes without a code scanner. If I change a hose or two I would like to clear the codes so as to know that I've fixed the problem. Will I be able to clear the codes and the engine light by disconnecting the battery?
Yes you can reset the light, but the key to this is you have to make the engine run a vacuum test of the evaporative system to know if it is fixed or not. That only occurs under specific conditions, temp 40-86F, fuel 15-85%, engine is at ambient temp (or within 10F I think), etc etc.
If you check the 2 spots in the above thread, I would bet $$$ that one of them is bad. Our's is a 2001 also and the first one happened 2 years ago.
