A/C PAG oil how much to add ?
Results 1 to 8 of 8
Thread: A/C PAG oil how much to add ?
    Jan 2004
    74
    Dose anybody know how much PAG-46 oil go's into the comp,....Thanks again.
    98PLY Mini-Van 149k
    Feb 2004
    664
    I cant remember for sure, but I think its 3 oz. The dealer should actually tell you that, or the place you bought it.
    Depends on the type of compressor you have as well...
    Also, if you replaced other components, such as the evaporator, condensor, etc etc.. each requires an ounce or so as well...
    Some people here will have that data... I dont have that.. I got it from the dealer. They may not tell you over the phone.. may have to show up.. unless you have a friend there etc..
    2006 DTS performance
    2005 Pacifica
    2001 SSEi Bonneville
    2001 RAM Conversion Van
    1997 Magna
    www.femint.com
    Jan 2007
    279
    It's ridiculous if they won't tell you that. If that's the case, ask the folks here.
    It's also in the factory service manual, if you have that. For some reason, on my '97 3.8L with front and rear air, I seem to recall about 10 oz. for the compressor, but maybe that was the total system capacity. I don't really remember now. I can take a look tonight.
    Chad
    2003 Honda Odyssey EXL (3.5L)
    1997 Town & Country LXi (3.8L)
    1992 Honda Accord LX (2.2L)
    1990 Chevy K2500 (5.7L TBI)
    Feb 2004
    664
    10 is probably the entire system.. something like
    3 compressor
    2 evap
    2 condensor
    2 rear evap
    1 all other
    something like that... depending on your system...
    2005 Pacifica
    1997 Magna
    www.femint.com
    Jan 2004
    74
    Thumbs down
    I should have "Know better".......We charged up the system, and when we turned on the A/C it started to "Screach".........And NO it not the belt....Back to square 1..........S#@&
    98PLY Mini-Van 149k
    Jan 2007
    279
    So you didn't put *any* oil back in the system?? Ouch!!
    Jan 2004
    74
    Quote Originally Posted by chad_webb View Post
    Added 5oz before charging....
    98PLY Mini-Van 149k
    Feb 2004
    664
    If you had 5 oz in there... should not have grenaded? if you only ran it for a few minutes..
    Sounds more like a bad clutch bearing... maybe ok..
    2005 Pacifica
    1997 Magna
    www.femint.com
