Originally Posted by
Pierre Cormier
I have a 2001 caravan 3.3l and 2 or 3 times a week the engine d'ont want to start, and i get p0353 p0352 p0351 codes. The dodge dealer changed the ignition coil ,and now they want to change the pcm module, is it possible or something else could be the problem. All the 12 volts wirring seem to be ok.
Sorry for my english
Pierre
Have you tested your battery? The codes refer to a problem getting the correct amount of power through to the plugs.
Since you are getting all three codes at once, I would suspect an electrical system problem for sure. At the very least, clean the battery terminals.
I would also have your battery tested. If it tests good, have the alternator tested. Most large parts stores will do the tests for free.
When troubleshooting, always assume the simplest cause first!
'02 Chrysler Voyager
Short Wheel Base
2.4L 3 Speed
102,000 Miles
