Window won't go down
Page 8 of 11 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 71 to 80 of 108
Thread: Window won't go down
  1. #71
    Jan 2009
    1
    AutoZone and Advance sell the whole shootin' match for $89.99 and says "Dorman window regulators are direct replacements and are re-designed to improve known failure points."
    http://shop.advanceautoparts.com/web...___#fragment-3
    http://www.autozone.com/autozone/par...30_13036_78655
  3. #72
    Aug 2008
    105
    Quote Originally Posted by Alex View Post
    Try this, it worked for me! (2x in 2 years)
    Open Door,
    Place finger on the switch for the down position,
    With your other hand, Slam door closed real hard ... while finger is still on the button, watch window resume operation.
    Repeat if necessary.
    Enjoy!
    THIS WORKS!!!!! THANKS!!
    2005 Chrysler Town and Country Touring 3.8L
    My DIY Contributions:
    Lower Radiator Tube Replacement
    http://forum.chryslerminivan.net/showthread.php?t=14636
    Leaking Steering Rack - Added lucas oil in winter of 2010-11 no leaks since then, but replaced PS Reservoir (9/2012 no leaks)
    EGR Valve - FIXED 5/27/11
    Front Brake Pad/ Rotors replaced 93k
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
    Windshield, rear brakes, tranny flush, , oil pan is rusted bad!
  4. #73
    May 2008
    7
    Open Door,
    Enjoy!
    This guy is a freaking genius! Window works fine now.
  6. #74
    Jun 2010
    115
    6
    My passernger-side window has only worked once in the last year. Didn't need it much. I went out about 10 minutes ago and did this procedure (if you can call it that)........didn't work. Tried it again and damned if that window didn't begin working perfectly.
    Alex is a genius !!!!
    Open Door,
    Enjoy!
  7. #75
    Jun 2009
    Jefferson City, TN
    3,051
    I had to do that to my 03 quite a few times.... eventually the window regulator will need to be replaced... but it works well till it finally breaks.
    Jeff
    Current:
    Previous minivans:
  8. #76
    Jun 2010
    115
    6
    Quote Originally Posted by chuckiebtoo View Post
    Now that the "Alex bump" made my passenger window work, it goes up and down so much better than the drivers' I need to lube/grease that one.
    Any great "Alex-type" easy fix for it??
  9. #77
    Sep 2011
    West Virginia
    3
    I know it sounds strange, but this also worked for me. I had to slam the door pretty hard, but it actually did work !
  10. #78
    Dec 2011
    WI
    2
    Slamming the door didn't work for me, so then I tried pushing on the rubber weatherstrip as mentioned somewhere in this thread, that didn't work either, so I just held the switch down and bumped the glass with my fist, volia, the window went down!!!! I love it, thanks a lot!!!!!!!!
    Is there anything I could lubricate to keep this from happening again? I did wipe a little armorall on the weatherstrip.
  11. #79
    Nov 2011
    Tennessee
    144
    Vaseline on the weatherstrips. Rubb it in real good and wipe off excess. It's a good thing to do to all of your rubber seals every so often. ESPECIALLY on convertibles. Keeps them pliable. Also if you have some crust buildup on the top edge of your glass about 1/4 down, take some washer solvent and clean it off. I have some fantastic lube we use now for glass channels, but the name escapes me at this hour...lol..i'll post it later. K-44 is one of them
    Chrysler Master Technician
    Electrical & Driveability
    DodgeForum.com Moderator
  12. #80
    Sep 2012
    1
    2012 Work on our 2005 Dodge Gran Caravan
    Open Door,
    Enjoy!
    My husband was searching you forum for answers related to our driver's side window not working.
    I was out of town for 3 weeks. My husband joined me and parked my car at the airport for a week.
    When I returned to drive my mini van only the driver's side window would not roll down. The passenger side was fine. I had had no problems before this. My husband went out and tried this.
    My inoperable window rolled down fine! It must have just gotten stuck or something.
    Thank you. Thank you. How folks it is worth a try before an expensive repair.
  1. Power Window Help
    By Dexterdog in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-02-2010, 08:36 PM
  2. window problem
    By hlplshalr in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-15-2008, 08:09 PM
  3. Window Sticker
    By From A Buick 8 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-25-2007, 10:33 AM
  4. Window power regulator popped, window fell down
    By arrio in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-09-2007, 09:00 AM
  5. Window
    By vanlover2 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-27-2004, 04:23 PM
