Timing Belt or Chain? 2000 Dodge Caravan SE Sport
Results 1 to 8 of 8
Thread: Timing Belt or Chain? 2000 Dodge Caravan SE Sport
    Jun 2007
    2
    Timing Belt or Chain? 2000 Dodge Caravan SE Sport V6
    Mar 2007
    Western Taxachusetts
    565
    27
    3.3 & 3.8 engines have a timing chain
    Jun 2006
    There and back again (NC)
    378
    Post
    Quote Originally Posted by rrf View Post
    The 2000 year model had the option of four engines. Three of which are V6s and the other is a 2.4L four cylinder.
    Timing Belt Engines: 2.4L Inline 4 cyl and the 3.0L V6 Mitsu engines
    Timing Chain Engines: 3.3L V6 and the 3.8L V6 (Just as Flavife has mentioned)
    Hopefully that helps. Don't be afraid to use the search feature. There is a vast amount of knowledge to be gained from the archives.
    _____________
    Brian
    2003 DGC Sport 3.3L 155k
    Jul 2003
    High Ridge, Missouri
    4,760
    Welcome to the Forum rrf. As you can see, you are NOW in good hands.
    Avatar: EconoVoyager Concept
    Jun 2007
    2
    Mahalo!
    Jan 2004
    74
    If you have a belt........Replace the water pump also at the same time.! I changed the timing belt at 75K and the my water pump started leaking at 125K.........The job was a PITA took me 15hrs todo . But saved myself around a $900
    98PLY Mini-Van 149k
    Jul 2003
    4,760
    PDshooter is correct. If you have a 3.0L with a belt - CHANGE the water pump while you are in there. MURPHY's LAW Applies. The 3.0L Belt/Pump job is not hard, just time consuming. Definitley NOT one of those side of the road jobs, although I have done it on the side of the rode, twice on 2.2L Chrysler 4 Cylinders.
    Jun 2006
    378
    Quote Originally Posted by DSMLVR View Post
    Just to highlight what DSMLVR has written before: http://forum.chryslerminivan.net/sho...n+interference
    It should be stressed, always replace the timing belt at specified service intervals. Some engines like the older Ford 2.3L inline 4 cyl did not mention anything in the owner's manual to replace the timing belt, even though it had one! So much for letting inexperienced owners know the warning when they could be on the side of the road waiting for a tow.
    I have read many owner's manuals before, they range anywhere from 40k (overkill) up to 110k (pushing it) miles before change.
    The other car I drive has a non-interference engine which is a 2.5L V6 in a '93 MX6. The burden of worry can be much less if the belt did break before the scheduled service. It is listed to have timing belt replaced at 60k mile intervals, I hate it when it comes time for that. That engine is not easy to work on.
    _____________
    Brian
  1. Timing Belt (Chain?) Cover Leak?
    By SomeYahoo in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-15-2008, 02:24 AM
  2. 2001 Town 'N Country , timing belt or chain
    By 13ducati13 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-01-2007, 03:40 PM
