P1684 and P0442
Results 1 to 10 of 16
Thread: P1684 and P0442
    Jan 2007
    25
    2
    P1684 and P0442
    I have a 2003 Chrysler Town and Country Van and the check engine light just came on this morning. I got the following codes and would like to know what they mean:
    P1684 and P0442
    I just had the oil changed and am wondering what could be wrong now. Any help would be greatly appreciated. Thanks!
    Apr 2007
    SoCal
    5,328
    1684 just means the battery has been disconnected. Disregard this one.
    0442 means you have a small leak in the Evaporative Emissions or EVAP system. Check all those small vacuum hoses for cracks.
    Jan 2007
    25
    2
    Thanks RIP...I'll give that info to my mechanic and see what he comes up with. I appreciate your help!
    Jun 2007
    Marion, Illinois
    37
    I am working on solving a evap code myself on mine, I am starting with one of the common problems which is the gas cap..........
    here is the kicker...a aftermarket cap that has no little tether on it to hang the cap by is $12.99 at my local parts stores.
    a factory cap with the tether is $5.85...which is what I bought.....one of the rare cases that a factory part is cheaper than the aftermarket
    Mar 2007
    Arizona & Washington
    218
    My 2003 3.3 eng. had the same P0442 leak that eventually developed into a P0455 Gross leak. Turned out to be a small approx. 2 inch long rubber coupling hose under the air cleaner box. It connects a metal tube from the evap. cannister to a plastic tube going to the purge solenoid. A bad crack occurred because these tubes were way out of alignment. The air cleaner box must be removed to get to this hose but is very easy to do . Jim
    Jun 2009
    4
    0442 error. I have a 2002 Caravan with the 3.3L engine. I pulled off my airbox looking for a 2 inch hose, and didn't find one. One metal line and one rubber line that connected to the washer bottle. Your thread (rangercreek) stated a 2003 model. Could my 2002 be a different layout perhaps? In any case I will continue my search for the cannister, purge solenoid and test pump (underneath), and look for more hoses.
    Dec 2008
    1,985
    Aftermarket gas caps dont have the tether because they arent made for any specific application,that same cap could be used on a Ford Ranger for example,or a GM pickup.If it has a tether,the dealer will automatically get the sale over the parts stores....that is if the driver HAS to have the tether.Personally,the tether is a convenience and a great way to avoid losing the cap (and tripping the engine light).I replaced it recently just as a matter of course.
    Jul 2009
    1
    0442 eroor code
    Quote Originally Posted by rick2wheels View Post
    I have a 2002 T&C with 3.3L engine and just fixed my similar error code (456) by removing the air cleaner box and locating the wrapped bundle just beneath and to the right of the air box mount. You were close when you first looked but missed the 2 wrapped vacuum lines and 1 wiring bundle that leads to the vacuum leak detector solenoid near the passenger headlamp. It's there so look again.
    The culprit, in my case, was a T fitting with cracked rubber hose on both sides. I purchased a 6 inch section of vacuum line from Kragens, removed the T fitting since I don't want it in there to cause any more problems, and replaced it with the new line. Fixed the vacuum leak and error code is gone.
    Before doing this, I followed the mfgs. diagram, went under the car and traced all lines from front to back of the vehicle and then removed the left rear wheel splash guard to check on the fuel filler and other hoses in the fender. All those lines are made of a more durable plastic or aluminum material and were fine - the line I ended up replacing next to the air cleaner box was rubber that had cracked from heat and age. Luckily a simple fix.
    Hope that helps.
    Nov 2008
    225
    I left the oil filler cap off the 04 once and it threw that code as well. (P0442).
    2015 GC R/T 3.6l
    2007 Durango Night Runner 5.7l
    1996 Econoline E350 7.5l
    Jun 2009
    On the world wide web
    715
    Quote Originally Posted by Geek4rent View Post
    Yeah I know about the price that the auto parts store wanted, i just replaced my gas cap, and it didnt come with the hole to put that hanger in so you dont loose it. But a tab was there so you can push it out and place that plastic piece in so you dont have to obsolete that retainer for the gas cap..should of done my research on that..
  1. P1684 code
    By GrandCaravan in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-01-2013, 06:42 PM
  2. Codes P1684 and P0456
    By Jeepman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-23-2011, 08:17 PM
  3. Help, Key Codes: P1684, P0442, P0456
    By ron semko in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-23-2008, 11:17 PM
  4. P0442 & P0455
    By Gino45 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-07-2007, 05:20 PM
  5. New code...P0442
    By psal2 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-07-2007, 03:48 PM
