Is the cover/gasket bad or just leaking? Did you try a tighten down of the bolts on it already? NOT real tight, but snug the bolts down and see if (IF leaking IS your problem) it stops. The service manual calls them CYLINDER HEAD COVERS.
Here is the 2002 Service Manual instructions:
CYLINDER HEAD COVER(S)
DESCRIPTION
The cylinder head covers are made of stamped
steel. The covers are sealed with steel reinforced sil-icon
rubber gaskets. The cylinder head cover uses
rubber isolators at each fastener location .
NOTE: Due to the tight packaging near the cylinder
head covers, which makes spill clean-up difficult, a
spill during an engine oil change may be misinter-preted
as an oil leak. When investigating an oil leak
in the location of the cylinder head covers and
intake manifold, follow the procedure found in Oil
Leak Diagnosis (Refer to 9 - ENGINE - DIAGNOSIS
CYLINDER HEAD COVER -RIGHT
REMOVAL (REAR COVER)
(1) Disconnect negative cable from battery.
(2) Remove the wiper module. (Refer to 8 - ELEC-TRICAL/
WIPERS/WASHERS/WIPER MODULE -REMOVAL)
(3) Disconnect spark plug wires from plugs.
(4) Disconnect power steering pump supply hose
support clip from cylinder head cover .
(5) Disconnect PCV hose from cylinder head cover.
(6) Remove cylinder head cover bolts.
(7) Remove cylinder head cover and gasket INSTALLATION
(1) Clean cylinder head and cover mating surfaces.
Inspect cylinder head cover surface for flatness.
Replace gasket as necessary.
(2) Inspect seal on the cover bolt for wear or damage.
Replace bolt assembly as necessary.
NOTE: The cylinder head cover bolts contain a
torque limiter sleeve and a seal (Fig. 26). The seal
and torque sleeve is replaced with the bolt.
(3) Assemble gasket to cylinder cover by inserting
the bolt assemblies through each bolt hole on the
cover and gasket (Fig. 26).
(4) Install cylinder head cover and bolts (Fig. 27).
(5) Tighten cylinder head cover bolts to 12 N·m
(105 in. lbs.) (Fig. 27).
(6) Connect PCV hose to cylinder head cover.
(7) Connect power steering pump supply hose sup-port
clip to cylinder head cover (Fig. 24).
(8) Connect spark plug wires to spark plugs.
(9) Install wiper module. (Refer to 8 - ELECTRI-CAL/
WIPERS/WASHERS/WIPER MODULE -INSTALLATION)
(10) Connect negative cable to battery.
CYLINDER HEAD COVER -LEFT
REMOVAL (FRONT COVER)
(1) Disconnect spark plug wires from spark plugs.
(2) Disconnect crankcase vent hose from cylinder
head cover.
(3) Remove cylinder head cover bolts.
(4) Remove cylinder head cover and gasket.
INSTALLATION
(2) Assemble gasket to cylinder cover by inserting
the fasteners through each bolt hole on cover and
gasket (Fig. 26).
(3) Install the cylinder head cover and bolts (Fig.
27).
(4) Tighten cylinder head cover bolts to 12 N·m
(5) Connect crankcase vent hose.
(6) Connect spark plug wires to spark plugs.
Since you did not tell what year you have , this is all the info I can give. It is pretty much the same for all years.
GOOD LUCK
Avatar: EconoVoyager Concept
