bolts to egr valve gone or broken off
Results 1 to 8 of 8
Thread: bolts to egr valve gone or broken off
    May 2007
    4
    I'm new to this site. I was told that dealer not responsible for bolt problem because they did not have to mess with it when they recently replaced the fuel rail under a recall. They say the bolts holding the exhaust pipe to the egr may have broken off or fell out from vibration. Any comments regarding my 96 T&C
    Jan 2007
    279
    I would recommend figuring out which it is before getting excited. If the bolts fell out from vibration, then count your lucky stars, and use a paper clip or other device to determine how long the replacements need to be. I believe it's either a 6mm or 8mm thread, coarse pitch (M8 x 1.25 IIRC, not sure on the 6mm)
    If, on the other hand, the bolts were broken off, curse and swear for about 5 minutes as you get to remove the air intake plenum to either drill out the bolts or replace the plenum. It's really not that hard, but it does take some time, especially if you haven't done it before. I would then start researching how to remove broken bolts. I've used both hydrochloric acid (swimming pool acid, many safety precautions to be worried about) and electrolysis to remove rust before, and have heard of folks using it to remove the rust from around these areas to help in freeing it up enough to be able to remove it without damaging the threads in the aluminum plenum. This of course is after the penetrating lube/easy out extractor doesn't work. Also, these methods are time consuming (on the order of days), so you have to compare that against the roughly $300?? to replace the intake plenum. Perhaps one could be had on ebay for less?
    How many miles on the van? Depending on mileage/maintenance history, if you end up removing intake plenum, probably a good time to do new plugs/wires and valve cover gaskets (f you have any oil leaks in that area), as the same components must be removed to get at them. Also check rear heater lines at this time for rust
    and decide if that will be replaced at the same time.
    I'm not one to recommend just wildly replacing parts, just suggesting you evaluate if the items considered "routine maintenance" are getting anywhere close to needing service and attempt to kill several birds with one stone.
    If you're just looking for someone to blame, then you need to know whether or not the bolts were broken before they replaced the fuel rail. I'm not certain, but I wouldn't say that it's impossible to replace the fuel rail without removing the plenum, so they may be telling the truth when they say they didn't mess with it when replacing the fuel rail.
    2003 Honda Odyssey EXL (3.5L)
    1997 Town & Country LXi (3.8L)
    1992 Honda Accord LX (2.2L)
    1990 Chevy K2500 (5.7L TBI)
    Apr 2007
    San Diego
    5,243
    If the bolt heads are sheared off and the remaining end of the bolt shaft is nice and shinny, I'd lean towards - they did it. Not conclusive but, a clue. If the bolts are missing, as chad said, thank your lucky stars.
    May 2007
    4
    bolts to egr
    Thank you both. I will find out on thursday and definitely let you know the outcome
    Sep 2005
    Massachusetts
    246
    12
    Not to add more fuel to the parts fire but if all that stuff is off you should check/replace the coolant lines to the back of the van if you have the rear heat/AC.
    Skidad in MA
    2000 AWD T&C Limited 60,000 miles
    May 2007
    4
    bolts and gasket were replaced by dealer at no charge while stating that they did not cause them to fall out. So I'm happy with the result, but not the fact that they didn't spot it the first time I complained about an exhaust leak. Thanks for all the great input to the newbie! DRTEDDC IN NC.
    Jan 2007
    279
    So it sounds like the bolts were missing and not broken off. As mentioned, count your lucky stars.
    Not to minimize the fact that the dealer did it for free, but the gasket is about a $2.00 part, and probably about the same for the bolts, and installing them is a breeze. I'd guess you'd have gotten more resistance had the bolts been broken off, as that repair would've been much more involved.
    Glad you got it fixed.
    May 2007
    4
    Yes, I am fortunate. Now that the bolts are in, they are easy to see. I wonder if that would be covered on the standard lifetime emissions system warranty, asuming there is one? Just a thought.
  1. Water Pump--Broken Bolts
    By 4breezes in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-04-2010, 09:52 PM
  2. Broken distributor cap bolts
    By Infinitrium in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 11-02-2009, 12:34 AM
  3. Broken water pump bolts
    By tempfixit in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-11-2009, 07:45 PM
  4. How to reach valve cover bolts
    By 3vanman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-10-2008, 05:06 PM
  5. broken water pump bolts 2000 caravan 3.3
    By jfrocker in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-27-2007, 12:54 PM
