No Heat
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 64
Thread: No Heat
    Nov 2013
    Kentucky
    161
    No Heat
    I finally got my thermostat replaced, no leaks but there is still no heat. Do you think maybe the heater core is clogged? It just had a new radiator put in before I bought it so the coolant is fine in it and not in need of replacement. Is there a way I can unclog the heater core myself or should I take it to a shop. If I do need to take it to a shop how much should I expect to pay either to flush or replace it. Thank you everyone who helped me get the thermostat in. I plan on buying the tools I need to do the O2 sensor maybe this weekend. Oh, 95 Plymouth GV with 3.3L engine
    2005 Chrysler TC Touring 114,000 miles Purchased 11/2/13
    2004 Dodge GC Purchased 203,605 miles 1/8/16
    Scrapped this one1996 Plymouth Voyager SE with 124,900 original miles on it. Purchased it on 01/26/15 for only $800
    RETIRED THIS ONE 1995 Plymouth GV SE 203,512 miles 3.3 liter purchased 11/11/13 for $500
    Jun 2011
    SE Michigan
    4,334
    Are the hoses in and out of the heater core hot? The vac check valve in the heater line needs to be open (no vac to small line) for coolant to flow.
    Your has a rear heater, is it getting hot? It uses the same check valve as the front.
    If you determine the heater core is plugged, you can try to clear it out with a garden hose. Keeping in mind that whatever might be in it could also be sealing up any leaks that could be hiding.
    Sometimes power flush=leak.
    2013 TC Limited Black/Graystone Custom ordered 5/13
    Luxury non Stow & Go buckets, Tow and almost everything else. Lifetime Max Care warranty. Driven to 36 states so far.
    1994 Grand Caravan SE Sport, 3.3L, 350,000+ miles and counting. Original engine and trans. Bought it new and have driven it to 48 states. Now my daughters daily driver.
    Nov 2013
    Kentucky
    161
    The rear heat seems to be colder than the front. It was 12 F this morning and I would estimate the front heat vent to be blowing about 30(depending on the outside temperature). I just went out and started the van and let the engine warm up and checked, the rear air seems to be colder than that coming out the front vent. It is still about 17 out, I may try to check the heater hoses later this afternoon when I get home if it warms up a bit first. I have to get the manual out and locate those hoses first. I know that they are small diameter hoses that go back to the firewall and I think they are similar to garden hoses in diameter, is that correct. So if the top hose is hot and the bottom hoses isn't, then that means the core is clogged. Is that correct?
    Feb 2013
    15
    Also check your heater control valve! It's inline with the heater core . It's vaccuum control maybe clogged or not operating? I have 1991 voyager with front heat only and I get only around 110 degrees out of the vents in this weather!
    Nov 2013
    Kentucky
    161
    Quote Originally Posted by John1425 View Post
    I was just reading another another post about that valve but it was in a Gen 4 vehicle I think so I wasn't sure the info applied to my van. Is this the inline valve with an arrow on it? And you are saying that there is a vacuum hose attached to it too? Thanks for the input.
    Feb 2013
    15
    I would think a 1995 would have one. Yes it has a n arrow that indicates flow direction. It opens when you adjust your heat.
    http://www.youtube.com/watch?v=5h1bnUUZmd0
    Jun 2011
    SE Michigan
    4,334
    Quote Originally Posted by greginky View Post
    You might recognize this photo better.
    [IMG][/IMG]
    The important thing is to get heat; the valve has to be open. Meaning no vac to the small line and the spring tension is holding the lever down. You should be able to move this lever with your fingers.
    Nov 2013
    Kentucky
    161
    Okay, I just went out to the garage and looked. All i had was a small light on my key chain so I couldn't see very well. Where exactly is this lever, I felt around and on the passenger side I could feel something like a lever behind the hoses. If that was it then I could not get it to budge. The vacuum line seemed to be okay. Does this lever move up and down? I could not find a spring either.
    Nov 2013
    Kentucky
    161
    I found this photo on Auto Zone [IMG][/IMG] I will check it closer when I get home. I hope this is the problem because it is only $14 and doesn't appear too hard to put in.
    Feb 2013
    15
    That vaccuum diapharm has a hose and if it's running with heat on that flap should be open. If you pull that vaccuum hose off I it should close. But it could be corroded inside or clooged.
