I've owned this van about a year. the two things definitely wrong with it when I bought it were the wipers did not work, probably a BCM problem so I just straight wired them to run off a toggle switch. the second problem was the gauge cluster sometimes not working. I took it out and fixed bad solder of printed circuit. Put it back in and it worked for about 6 months. Now it has stopped working again and I replaced it with a junkyard version.
Still did not work. I have done things such as disconnect battery, checked connections at AC controls, tried to a self diagnosis with trip meter, no luck. Checked fuse in box on top of BCM just to left of pedals.
Is there a fuse I could check elsewhere. Could it be the BCM. thanks for any input
