Removing Power Door Lock Relays from Junction Box - '98 Voyager
Results 1 to 2 of 2
Thread: Removing Power Door Lock Relays from Junction Box - '98 Voyager
    Nov 2013
    29
    If one removes the three door lock relays noted Door Unlock, Door Lock and Left Door Unlock Relays as shown on the excellent Junction Block diagram provided in Post #7 in the fuse box?? thread, will it do anything other than disable the door locks.
    One can't just remove the 40 A 'DR LCK/SEATS' fuse from the PDC as shown in the pics of the PDC cover in Post #4 of the above thread or presumably the Power Seat won't work.
    Desired result is NO Power Door Locks, while retaining use of Power Seat.
    Per Haynes Wiring Diagram for Typical Power Door Lock Systems, all Lock Motors and Sliding Door Contacts are powered through these three relays. No power, no power locks... hopefully with nothing else affected.
    What say Ya'll?
    TIA,
    Steve
    Jun 2009
    canada
    60
    I would remove the three relays and then check to see if the power seats work
