A604 Valve body diagram
Results 1 to 3 of 3
Thread: A604 Valve body diagram
    Dec 2003
    982
    Does anyone have an assembly diagram for the valve body on 1997 A604? What I need is the location of all the spring stoppers, springs, valves and such. My tranny was rebuilt before me ones already and I think they assembled the valve body incorrectly. I would like to take it apart and make sure that everything is in the correct positions.
    Dec 2006
    1,106
    31
    My alldatadiy.com account has diagrams of the valve body (but the alldatadiy terms and conditions mean I can't copy them here). But I'm not sure that it is much more detailed than you'd find in your manual. It shows the locations of check balls and springs and a rough diagram of the few hydraulic valves that it does have.
    On your previous post re. what sounded like air getting in the fluid, I'd agree with whoever said to check the filter -- I would think that would be the most likely place air would get in - at the o-ring or seal around the filter neck. Air is also more likely to get pulled in when the fluid is thicker.
    - G
    1998 Grand Voyager @334,000mi, 3.3L FFV V6
    Dec 2003
    982
    Well I took the pan off tonight and the filter seemed to be on there ok. I pulled the valve body and remembered something. When I did the rebuilt, I found that the snap ring that hold the low/reverse piston in place broke apart at the ends and is now next to impossible to remove. That was the only piston that I haven't changed the seals on. Is it possible for the air to be getting in there and causing the sound?
    The sound is like a squeaking but disappears as soon as the car shifts into 2nd. It is also more pronounced when I shift the gear into reverse, sounds kinda like a clunk with a squeak.
  1. PCV valve replacement - trouble with valve cover insert
    By bnut2000 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-09-2014, 08:35 AM
  2. part list diagram and/or explode part diagram
    By wvusa in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 03-11-2009, 09:25 AM
  3. Replacing a 41te Valve Body. Ive never done it b4. Any help appreciated.
    By djshyc in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-06-2009, 08:16 PM
  4. A604
    By dw8 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 11-02-2008, 12:38 PM
  5. high pressure port valve=charger valve???
    By mewant2b in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-24-2008, 05:41 PM
