HELP, I'm stuck.
I am in the process of replacing the ignition coil on my 2003 T&C, 3.8L, but first I must move the power steering reservoir out of the way. My Haynes manual says to remove the two bolts that fasten the PS reservoir bracket to the engine, which I have done.
The next step says to "Loosen, but don't remove. the single nut. Lift the reservoir up & disengage the lower mount from the stud." I must be blind because I cannot find the "single nut" to loosen and therefore I can't lift the PS reservoir off the stud. It looks like it should be simple to do, but where is the nut they mention???
Your help will be greatly appreciated.
THANKS!
THANKS!
