99 Town & Country won't turn over????
Results 1 to 5 of 5
Thread: 99 Town & Country won't turn over????
    Sep 2006
    5
    I've got a 99 Town & Country AWD with a 3.8L. It has had a problem for a while where the gauges would quit working while I was driving it. You tap the dash they'd work again. Then it would sometimes not turn over when I tried to start it. Again tap the dash it would turn over and start. But now nothing, it won't turn over and the gauges don't power up. All the warning lights at the top of the dash work and all the accessories work.
    I have replaced the starter, ignition switch and starter relay.
    I have a feeling it has something to do with the gauge cluster. But I can't figure out why the gauge cluster would keep the engine from turning over. And if it is the gauge cluster what's the problem?? And is it fixable or do I have to replace the whole cluster???
    I need to get this van running!!
    Jan 2005
    Fayetteville, NC
    9,436
    It sounds like it could possibly be in the ignition switch WIRING inside the dash. If there's a loose connection or ground or something, that may explain why tapping the dash used to make it work. I know, that problem, if it IS the problem, could be near impossible to trace.
    I hope someone has a better idea.
    Feb 2004
    664
    if you do a search of the forum there are lots of people with the same issues.. apparently it seems to be in the cluster itself and many have tried (unsuccessfully) to replace body computers etc... so, buy a used one (entire cluster) for 1 dollar, or whatever, of ebay.. make sure its the proper year as the connectors on the back change, and off you go... watch out if you blow the IOD fuse in the process, locks wont work , radio etc..
    2006 DTS performance
    2005 Pacifica
    2001 SSEi Bonneville
    2001 RAM Conversion Van
    1997 Magna
    www.femint.com
    May 2006
    New York, NY
    237
    2
    You are right to suspect the gauge cluster. Search previous posts as this is a common problem.
    Repairing it will require resoldering a few connections on the computer board of the cluster.
    2007 Town & Country Touring, Special Spring Edition, 3.8
    Past:
    2000 Town & Country LX, 3.3
    1992 Voyager, 3.0
    Aug 2005
    57
    Hmm, I had a similar issue on my 98 GC - changing my 4+ year old battery fixed it
  1. Turn signal problem 1996 Town&Country
    By JMW in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-21-2013, 04:06 AM
  2. FS: 96 Town & Country
    By 96T&C in forum For Sale
    Last Post: 12-27-2010, 12:57 PM
  3. 05 town & country
    By smatt792006 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-13-2009, 03:23 PM
  4. My 2002 Town and Country minivan won't turn on at the first attempt
    By turrubif in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-22-2007, 07:46 PM
