hey seems like im having the same problem as the other guy here... i just bought a 93 T&C very clean 120,000 miles only issue when i bought it was it needed a half shaft and new exhaust..
but as i drove it it started giving me issues stalling but only... only when it was warm and after i shut it off... i can drive it all day without an issue... but if its up to operating temp im guessing the 180-200 degree area.. and shut it off it studders really bad at start up... you have to hold the pedal all the way down to start it... and then rev it a bit around 2,000 rpm with some spitting and sputtering before it will even go into drive or reverse... it will hang in the normall 750-1000 rpm at idle at this time seeming pretty smooth little sputters but once you toss it in gear it dies... eaither have to let it cool down or let it run for about 5 minutes before its driveable again...
just so you know as of now it has a brand new cat, new tune up plugs wire and a new coil pack... a new idle air controll valve.. and a new o2 sensor.
so unless this temp sensor is bad which i would assume it would toss hott and cold signals out to the dash? not sure but it seems to send signal fine.. did look like a 3 wire sensor though..
if not im kinda lost next thing i was gonna try was the vacume system evap and such being ive had this issue before in other vehicals...
the fuel system has been cleaned new filter injectors sprayed through. still not doing it every part seems to help a bit but not cure it any ideas?
