Rusty strut towers
Results 1 to 10 of 11
Thread: Rusty strut towers
    Nov 2004
    GR MI
    35
    Rusty strut towers
    Is there any rhyme, reason, or pattern to which vans tend to have the rusty strut towers? I have no problem with it but two of my neighbors do - one t&c and one GC.
    1974 Pymouth Voyager
    1993 Dodge Caravan
    1994 Dodge Gran Caravan 115,000
    1997 Chrysler T & C 142.000
    1997 Olds 88 121,000
    1982 John Deere 212 just rebuilt
    Jul 2003
    High Ridge, Missouri
    4,806
    I have seen no Rhyme or Reason or any sembelence of reason for the problem. My theory is improper preperation BEFORE the underbody E-coating and the base prime dipping/coating is applied. I know that if the body-in-white (bare metal body from the body shop) is not cleaned correctly and completely, the processes after that are invalid, that is, they do not stick and protect properly. I worked inspection in the body shop/paint shop in an assembly plant (the mini van plant 1992-1993) for MANY YEARS. I have been away from it (retired 1993) for 13 years (5 years before the vans now having the problems). So my thoughts are just that ,a theory.
    I know that some in Michigan snow belt and some in the MidWest area have the problem. While I would expect it from Michigan, not expected elsewhere. In reality, it should NOT BE EXPECTED FROM ANY REGION.
    Avatar: EconoVoyager Concept
    Nov 2003
    936
    It is almost always on the battery side only. LIke mine the other side is perfect. Every one I've seen is battery gassing. I know y wife hates my gassing :-)
  5. #4
    Jul 2003
    4,806
    I have had many people e-mail me for the TSB. They tell me they get it on both sides, with the battery side the worse.
  6. #5
    Feb 2004
    162
    One of the best features in my van are the motorized rear windows for when said gassing phenomenon occurs.
    Quote Originally Posted by sellinghomes4u
    2009 Honda Accord, 2.4 (Mobil1 5W-20)
    2009 Nissan Altima
    2000 Toyota Camry, 2.2
    1999 Toyota Camry, 2.2
    1995 Chevy S10 S.S., 4.3
    1985 John Deere 318 (Mobil1 10W-30)
  7. #6
    Jul 2006
    Fremont MI
    20
    Quote Originally Posted by DSMLVR
    My 99 T&C has it on the battery side. Nothing on the other.
  8. #7
    Sep 2005
    Massachusetts
    218
    10
    Yup, my new/used 2000 T&C has it on the drivers side and WILL need the fix, the other side is perfect. My 98 GC is juuuust starting to show a little bit of cosmetic rust and the ex-wife has a 98 also but it was fine as of 2 years ago when we split. The whole thing seems so random it's crazy!!!
    Skidad
    98 AWD GC LE, 190,000 miles (driving every day but available for sale)
    2000 AWD T&C Limited, 44,000 miles (sweeeeeeet)
  9. #8
    Jul 2005
    NJ
    1,562
    5
    I remember reading somewhere that the problem had to do with a manufacturing defect, namely a void left between two stampings that are welded to form the strut support, and that not all vehicles were affected. Still true that battery acid might make it worse. Perhaps an Optima-type battery would be a worthwile investment for those not yet encountering this problem?
  10. #9
    Nov 2004
    GR MI
    35
    I'll have to check my neighbor vans out to see if it's on both sides. If it starts from the surface a guy could stay after it, but if it comes from between the stampings you won't know until it's too late. I'll try to investigate that this weekend.
    1993 Dodge Caravan
  11. #10
    Nov 2003
    936
    On mine it's obvious it came from the surface but by the time you actually notice real issues it's too late. You need to repair it. I HATE RUST!!!!!!!!!!!!!!!!
  1. If I unbolt the struts from the strut towers...
    By ironman187 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-22-2010, 05:11 PM
  2. Monroe Quick-Strut or Gabriel ReadyMount Strut?
    By sideburns2009 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-07-2009, 02:09 PM
  3. Rusty strut towers
    By telerooster in forum The Fireplace
    Last Post: 03-17-2009, 10:08 PM
  4. Updated info on rusty strut towers.
    By DSMLVR in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-29-2007, 11:41 PM
  • You may not post replies
