97 T&C roaring noise in rear
Results 1 to 5 of 5
Thread: 97 T&C roaring noise in rear
    Apr 2007
    6
    I have a 97 t&c lx 3.8L i changed both rear wheel bearing assemblies thinking they were going bad with 244.000 miles on them but the roaring is still there. Anyone have any idea what else would be causing this? Also i replaced the fuel pump 1 1/2yrs ago but when the fuel gauge is down to a 1/4 tank the van will run out of fuel. Gauge was reading correctly before pump was replaced so i know its not the gauge itself, any ideas on this? Any info is appreciated.
    Mar 2008
    THORNTON-CLEVELEYS BLACKPOOL ENGLAND
    1,058
    Regarding the roaring issue... What condition are your rear tyres in? The reason I'm asking is that I experienced a similar issue and upon further inspection on of my rear tyres was out of shape witch was coursing a lot of road noise inside the van making me think it was wheel bearings!!! Can't help with fuel gauge issue, but I'm thinking of a sticking sensor!!!!
    Chrysler grand voyager 1998 3.3 LE.
    86874 miles on the clock with no real problems to mention..
    2001 Peugeot 307 (petrol) 46039 miles on the clock.
    Jul 2011
    47
    It stinks but the fuel pump assembly contains the fuel sending unit to the fuel gauge. You will need to replace the pump assembly again or live with it.
    Jun 2007
    1
    Nithawk2000 did you ever find the problem? I have the same issue replaced bearings and tires still roaring , thanks
    Dec 2013
    Va
    772
    I have had rear drum brakes cause the rumble, adjuster hardware sticks and the wheel cylinders stop releasing allowing the shoes to rub. I would clean and lube hardware and rebuild cylinders or replace.
    2013 GMC Acadia SLT 3.6l 45k
    2006 Town & Country 3.8 Touring 259k, 2nd engine, 2nd transmission
    2003 Grand Caravan Sport 3.8 264k
    1995 Jeep GC 4L 335k SNOW & GO-----------------1999 Jeep GC 4L 221k 2nd head
    2003 Grand Caravan 3.3::::::::::::::::::::::::::1997 Grd Voy 3.3 266k
    Gone but not forgotten: 2003 Caravan 3.3 Flex 443k original engine and trans & lighting strike sold 10/2013, should have never let it go.
    1992 Plymouth Voyager 3.0 sold 1999
    2000 Grand 3.3 201k sold 4/2016
    Good riddance:1996 Town & Country 3.3 when 2nd trans went 2003
