Disable alarm? - van won't start T&C
Results 1 to 5 of 5
Thread: Disable alarm? - van won't start T&C
    May 2006
    1
    Occasionally our 1997 T&C LXi won't start (starter turns but will not fire). After several hours of sitting, it starts. Have noticed that the alarm light was on on the dash. Is something in the alarm circuit making the car unable to start, say by a thief? Then it automatically resets later? The manual does not address this.
    No fuse is labelled for the alarm, that I can see. Disable the alarm system since we don't use it anyway. Thought this might be a way of seeing if it solves the problem.
    Other things I want to check are:
    Grounds - is this a common problem with these vans?
    Elec. connectors?
    Fuel pump circuit
    It does not stall while driving - but I will clean TB and IAC anyway. I know this was a problem w/ some years and models.
    Thank you for ANY advice.
    Pete
    Apr 2008
    Hamilton, New Zealand
    18
    Hi there
    My 99 Voyager (Right Hand Drive) has a similar problem. It starts and then stutters to an idle before cutting out. Alarm light comes on and stays on. Fuel pump is going crazy and the ASD relay is buzzing like you wouldn't believe. The Stealership here in New Zealand is keen to take $1500 NZD (around $1150 USD) off me to fix the problem.
    Any help with diarming the alarm thingee on these things and the above?
    Cheers
    Marouna
    "At the end of the day, it is night..."
    99 Chrysler Voyager LE
    72 Chrysler Valiant Charger
    98 Toyota Caldina GT-T
    Jan 2008
    Nova Scotia, Canada
    16,701
    Use this search criteria in Google and see what you get
    +"'vehicle theft alarm" +"no start"
    Should get this:
    http://www.google.com/search?q=%2B%2...e7&rlz=1I7RNWN
    with lots of info to look at, much of it pertaining to Chrysler products.
    Mar 2008
    14
    Peter, I've had somthing similar with my 98 Voyager in the past.
    When it wont start try removing the IOD memory fuse {10amp}, for 30 seconds or so, and refitting it. I,am told this clears faults from the body control module and it may then start, worth a try.
    The fuse is located in the fuse and relay centre under the hood and is at the top end.
    Keith
    Apr 2008
    18
    Cheers for the advice guys.
    I'll give it a blast and see what happens.
    Marouna
  1. How to disable the factory alarm
    By jrprich in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-14-2015, 06:01 PM
  2. Help! Can't disable vtss alarm!
    By andrewhgee in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-30-2013, 11:12 AM
  3. 2007 Chrysler T&C = WILL NOT START BC of ALARM
    By rdstrasser in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-10-2010, 09:51 PM
  4. disable overdrive
    By mecanovi in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-02-2010, 05:03 PM
  5. Car Alarm- no fob - Cannot Start Van
    By Evette22 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-11-2009, 11:23 PM
