Very bad oil leak
Results 1 to 10 of 12
Thread: Very bad oil leak
    Feb 2006
    3
    Very bad oil leak
    Hello all. I need some help with a very bad oil leak on my 96 Plymouth Voyager 3.0. It looked like the oil leak was coming from the front passenger side corner of my oil pan right next to the crankshaft pulley. Replaced the oil pan gasket thinking that was the problem. After the fourth attempt and fourth gasket, I have come to believe that the leak is not coming from the oil pan. I replaced the water pump on this vehicle just about 1.5 to 2 months ago. Had to remove the timing belt cover and timing belt to replace the water pump. I don't know if I could have done something while replacing the water pump to cause this bad oil leak. I'm thinking that the oil leak is coming from something above the oil pan and dripping down the side of the oil pan and onto the ground. Could anyone give me some ideas on what it might be? I could really use some help with this. Could it be coming from any of the seals? How could I determine where the leak is coming from? Thanks for any help that you can give me.
    Jan 2004
    74
    Clean off engine oil.........Replace the PCV . 3.0 are know tobe oil-leakers.
    CK PVC rubber hose. Not clogged.
    98PLY Mini-Van 149k
    Jun 2004
    rochester,ny
    736
    7
    2nd what the previous poster said , on the front of the engine pull that rubber hose that goes to the plastic resonator box and see if you have any white sludge in there if so the pcv valve is shot and is causing increased crankcase pressures which can increase problems with oil leaks , would also check your air filter while at it to make sure that isn't oil soaked .
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    48000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Mar 2006
    16
    The most common places for oil to leak from the front of that engine are 1. Valve cover, 2. crankshaft seal 3. distributor seal , 4 camshaft seals and last but not least the head gasket. Head gasket and valve cover is easy to see if you look from underneath the car. Camshafts will leak inside the camcover and run down front of engine and drip out next to crankshaft in most cases. Distributor seal will be visible if you look down from front on passenger side of engine. All are easier to find than to fix.
    JCM
    87 Caravan SE 3.0 230,000+
    New to the board not to the van
    Jul 2003
    High Ridge, Missouri
    4,760
    JCM IS correct, however alot of the leaks are caused BECAUSE of a plugged PCV and/or PCV hose. The pluged valve/hose do not allow the engine/crankcase evacuation system to BREATHE, causing an excessive pressure to build up inside of the engine. Any/all weak spots in the gaskets will be revealed with oil leaks at this time. It is the pressure trying to get out. Change them and take the pressure out of the engine and you WILL see a difference. THEN clean off the engine and keep an eye on it to see where any bad leaks may show because of the previous situation.
    PREVENTIVE MAINTENANCE DOES PAY.
    Avatar: EconoVoyager Concept
    Jun 2006
    2
    Is it hard to change the PVC? Where is it located on my 99 Voyager, 3.0?
    Dec 2003
    Eau Claire, WI
    2,800
    Quote Originally Posted by Professor
    There is a small hose coming out of the front valve cover on the engine (this is not the larger hose that leads to the airbox, that's something else entirely). Follow this hose to the point where it plugs into the block. Remove the hose, and you will see the PCV valve screwed into the engine.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
    Dec 2005
    NY
    3
    2 quart oil leak per week, on my '97 ,4 cyl Dodge Caravan. The engine is dry on 3 sides except back side and bottom. What's going on?
    Jul 2003
    4,760
    You may have a leak at the back side of your valve cover gasket. You may have a leak at the gasket at your cam sensor on the backside of the engine in the head. You may have a camshaft oil seal leak in the head. Check the easy things first.
    Feb 2004
    162
    Wash the engine down and keep an eye on it for a few days. Sounds like it won't take long to find it at 2 quarts per week.
    Just be careul to not get sensors, electronics etc overly wet in the process. I like to blow my engine off with a compressor after washdown.
    Good luck,
    Jay in MA
    Quote Originally Posted by russwr
    2009 Honda Accord, 2.4 (Mobil1 5W-20)
    2009 Nissan Altima
    2000 Toyota Camry, 2.2
    1999 Toyota Camry, 2.2
    1995 Chevy S10 S.S., 4.3
    1985 John Deere 318 (Mobil1 10W-30)
  1. another 3.0L oil leak
    By voyagerMike in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 08-05-2010, 12:30 AM
  2. oil leak
    By jdq in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-02-2010, 12:11 PM
  3. Evap Leak Large and Fuel Leak
    By rfrancis in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-24-2009, 10:20 PM
  4. Air leak
    By VJ from South Dakota in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-23-2007, 08:44 PM
  5. 99 2.4 oil leak
    By Vic in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-19-2006, 10:31 AM
