Strange turn signal problem
Results 1 to 4 of 4
Thread: Strange turn signal problem
    Mar 2006
    2
    I'm having a problem that happens intermittantly. When i go to use the right turn signal sometimes the indicator light will stay on even when the signal switch has returned to the centre position. When this happens the right brake light stayed on even when the vehicle was shut off (noticed it from in the house). To fix the problem i flick the signal from left to right a few times and it will be back to normal for a while. Vehicle is a 2000 grand caravan.
    any info would be greatly appreciated
    Dec 2005
    Toronto, Ontario, Canada
    363
    1
    Had the same problem in my '96 a few times. Each time it was the turn signal relay/flasher. Mine had daytime running lights, so the plug-in unit was always expensive. I think it was under the drivers side dash. It was dealer only at the time too.
    2015 Jeep Summit Diesel- Brilliant Black, Tan Leather
    Past Mopars:
    2004 Town & Country Limited AWD Brilliant Black w/Tow Package, NAV and Sat Radio, ATE slotted rotors w/ceramic pads
    1999 Jeep Cherokee Sport
    1996 Plymouth Gnd Voy LE
    1994 Dodge Gnd Caravan SE
    1989 New Yorker 5th Ave
    1984 Plymouth Reliant
    1979 Plymouth Caravelle T bar Roof
    1972 Imperial 4 dr
    1968 300 Convert.
    1968 Newport Custom
    1960 300F Coupe
    1960 300F Convert.
    1955 Windsor Deluxe 4dr
    Mar 2006
    2
    Thanks for the reply i will try that out first
    Nov 2003
    South Hills of Pittsburgh, PA
    1,298
    Actually, the DRL flasher is cheaper than the Non DRL flasher at my dealership.
    I paid $28 for it.
    The non DRL was $32.
    Since I WANTED the DRLs, I was willing to pay the lesser price.
    Non DRL Flasher:
    DRL Flasher:
    I believe even the non-DRL version is still a dealer item since it is considered a relay and not a 'flasher.' At least that is what the guy at Advance Auto said.
    Chas
    Chas Stokes
    2000 Saturn SL1 "ZUUL"
    2002 Hyundai Elantra (Stolen ) "ZUUL24"
  1. Turn Signal Problem
    By WKB in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-02-2013, 05:45 PM
  2. Turn signal problem 1996 Town&Country
    By JMW in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-21-2013, 03:06 AM
  3. turn signal problem
    By superflydudebike in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-22-2009, 04:11 PM
  4. Self Cancelling turn signal
    By hemicar in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-27-2007, 07:18 PM
